identifying L34
Posted 29 March 2007 - 01:00 PM
So story is one owner, slr 5000, faded paint, sat in his back shed for 20 yrs.
might sell it.
thinks it is red/black.
nobody seems interested? as recon he is asking way to much.
so been 4-5 months trying to get an invite to look at it. they say don't even bother, to expensive!
what got my attention is the story also says it came from the factory with flares etc.
from what I can tell is that may make it a L34.
were slr's factory fitted with flares?
If I finally get to look at this thing, I would like to have a better idea at what I am looking at.
So I did a forum search on L34, not much came back.
L34, M21 Gu4 on plates
usual slr numbers
HX engine prefix
flares, bonnet scoop.
gts wheels
twin point dissy
Hq brakes
interior the same?
anything else that is easy to see?
also build dates, were they all in one lot?
how many built?
are the cars documented like A9X's anywhere.
it is a little expensive for a L31 that neads resto, but cheap if it is a L34.
finally, what sort of price are L34's pulling? haven't seen one for sale for a while.
_MediuM16A2_
Posted 29 March 2007 - 01:07 PM
but im pretty sure they dont come with a centre console.. just a gearstick and boot on the floor!..
id imagine they'd go above 30k..
but yeah.. i dont know much wait for the pro's to answer.
cheers,
Ben.
Posted 29 March 2007 - 01:12 PM
L34's had HQ Brakes, GTS Wheels and Flares. No bonnet scoop. If it's got L34 on the plates, and they don't look like they've been removed, then chances are that it's an L34. L34's don't have a boot mat or centre console, to keep weight down
I THINK that LS1LX sold an L34 recently, not sure what he got for it.
Cheers, and good luck.
Tim
Posted 29 March 2007 - 02:26 PM
Posted 29 March 2007 - 02:30 PM
To add to what Tim has said, the engine number prefix should be HZ (not HX). Also, not only does the ignition system have a twin point dissy, it is a 4-lobe twin pointer with 10 outlets on the dissy cap and 2 ignition coils. The wheel rims are similar the GTS, but have a different offset and there is no bonnet scoop on any LH.
AFAIK L34s were all built in July/August 1974. They were not documented as well as A9Xs because GM-H weren't fully online with their computers in those days. Pre-77 stuff was all manually recorded.
Dr Terry.
_Yella SLuR_
Posted 29 March 2007 - 02:49 PM
_LH SL/R 5000_
Posted 29 March 2007 - 03:15 PM
_Herne_
Posted 29 March 2007 - 04:28 PM
Have a good look at a genuine L34 around the flares and you will see what I mean.
Herne
Posted 29 March 2007 - 05:22 PM
_Herne_
Posted 29 March 2007 - 05:38 PM
If I were considering buying one I would definitely accept REDA9X's offer of an inspection by one of the A9X boys. Thats probably the very best thing you could do.
Herne
Edited by Herne, 29 March 2007 - 05:40 PM.
_Rob 5000_
Posted 29 March 2007 - 05:49 PM
_pallbag_
Posted 29 March 2007 - 07:31 PM
A pic explaining this would be nice ?One tell tale sign that has been missed, is the washer/bracket on the flares under the hex bolts, L34 was the only car to have it.
_Toranamuk_
Posted 30 March 2007 - 07:02 PM
I havent picked up all my L34 bits yet, but i havent spotted a dissy in the pile yet, hopefully its in there somewhere.
Posted 30 March 2007 - 07:14 PM
_racyrabbit_
Posted 30 March 2007 - 08:41 PM
Posted 30 March 2007 - 09:05 PM
_Yella SLuR_
Posted 30 March 2007 - 09:13 PM
From factory yes, but a shit to tune, so most of em have been replaced with either a single point/coil dizzy or electronic, so not really a good indicator.Did all L34's have the twin coil twin point dissy ???
If the car's not too far away, happy to have a look for anybody, I only have eyes for LH's. I will be in Sydney/Brisbane over the next couple of weeks if that helps.
The clips, can't explain as I don't have a pic of them, and nobody that I'm aware of makes repro ones. I have seen the odd respray L34 that has new flares fitted, and these items lost, so even that is not enough to verify that it's an L34. Really need to know what your looking for. Then you also need to verify that it is an L34 engine, which is virtually all the L34 is, no L34, then just another LH SL/R 5000.
They tried to sell me my car as an L34, but I knew it wasn't. Was stoked that it was actually an SL/R 5000 though.
Edited by Yella SLuR, 30 March 2007 - 09:15 PM.
_Yella SLuR_
Posted 30 March 2007 - 09:17 PM
Mine has round headlights, but it aint an L34. Very easy to change.Round headlights on L34
Edited by Yella SLuR, 30 March 2007 - 09:17 PM.
_tazidvl_
Posted 30 March 2007 - 11:02 PM
Well not really just a non matching numbers car.also need to verify that it is an L34 engine, which is virtually all the L34 is, no L34, then just another LH SL/R 5000.
No HZ prefix block no flare clips etc etc but tags reading L34 and matching the vin and body number AND chassis stamp then its a L34.
If it has the block and all the other bits and pieces then that adds to the value but does not make it just another LH SLR 5000.
If hes is asking to much for a SLR but a good price for a L34 (and you dont know what a good price is) then I would guess he knows its just a SLR but trying to pass it off as something special.( or just does not really want to sell it)
Sound like your info is all second hand, and this will not help as a lot off people believe SLR should have flares therefore they MUST be factory fitted.
All the tell tale signs are easy to replicate but not a SET of matching numbers
_purpleLC_
Posted 01 April 2007 - 10:19 PM
Different diff housing and axles, front end, fuel line, manual choke on carby,
bigger brakes, and other little mods.
The L34 block had extra cast ribbing on the back of the block, this was brought over to the rest of the 308 engines.
#21
Posted 02 April 2007 - 07:32 PM
