9inch oil capacity????
13 replies to this topic
#1 _T0rana_
_T0rana_
Posted 03 April 2007 - 01:15 PM
iv heard a few different amounts, anyone know the exact?
i put in 2L so far and it seems a small amount for the giant diff.
the axels seem almost impossible to pull out again so i want to get it right (no plugs) :spoton:
thanx!
nathan
#2 ls2lxhatch
  • 5,335 posts
Posted 03 April 2007 - 01:29 PM
According to Castrol 2.3 litres for a 9" in a XY GT.
http://www.datateck....ke=20&Model=550
If you have an LSD make sure you use the correct oil.
#3 _T0rana_
_T0rana_
Posted 03 April 2007 - 01:37 PM
its locked with a spool :spoton:
thanx heaps... maybe 2L will be ok pretty close to 2.3
cheers,
nathan
#4 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 03 April 2007 - 07:28 PM
There are different style 9" housings and I am fairly sure these have differing oil capacities.
#5 _v8slrtorana_
_v8slrtorana_
Posted 03 April 2007 - 10:03 PM
On the passengers side of the case there is a filler plug, fill till oil starts to drain back out.
It can be undone with a 3/8 ratchet and extension bar, NO SOCKET req.
You will find 2ltrs will only fill to the bottom main cap bolt, a little more oil would be better. Submerge those bearings.
Ive got a 1" filler plug in my housing so i can see inside :D
#6 MRLXSS
  • 12,419 posts
Posted 03 April 2007 - 10:10 PM
I found in another post someone Said 2.1litres..
But i suppose it wont hurt to have 2.3. Ill be filling mine up soon too!
#7 _UC_CHEV_
_UC_CHEV_
Posted 04 April 2007 - 12:54 AM
no plugs on mine, its a brand new housing... there is a weird thing ontop of the diff maybe it is a filler, will have to chek that out for that extra 0.1-0.3L.
its got 2L in there now and both axels are in for life.
upgrading aswell 253toranass? how many bango's you blow up?
iv never blown a diff in my life.. trusty uc diffs :spoton:
#8 ls2lxhatch
  • 5,335 posts
Posted 04 April 2007 - 01:27 AM
As v8slrtorana pointed out there is a filler plug on the passenger side of the 9" centre ( not the housing). The diff is full when oil reaches the filler plug.
Edited by ls2lxhatch, 04 April 2007 - 01:37 AM.
#9 _ChiaLX_
_ChiaLX_
Posted 04 April 2007 - 06:30 AM
Mine takes 2.5litres. It is what they call a broadshoulder 9 inch and oil level is just over the axle tubes.
#10 _UC_CHEV_
_UC_CHEV_
Posted 04 April 2007 - 02:51 PM
:spoton: :spoton: :spoton:
#11 MRLXSS
  • 12,419 posts
Posted 04 April 2007 - 06:20 PM
ummmm 1,2,3,4,5 (three of them went bang, the other two i changed just to get better ratios)
That wasnt even from driving it hard, i am a pussy when it comes to sticking the foot down.
Edited by 253ToranaSS, 04 April 2007 - 06:20 PM.
#12 _Bomber Watson_
Posted 04 April 2007 - 08:50 PM
ok, now i worked out how to fill my new nine inch how do i get the old oil out of it???
this thread popped up at a convenient time lol.
#13 MRLXSS
  • 12,419 posts
Posted 04 April 2007 - 09:00 PM
i think there is another plug like that near the bottom bomber... have a look
#14 _v8slrtorana_
_v8slrtorana_
Posted 04 April 2007 - 09:41 PM
They dont have a drain plug as standard.
If yours has a drain plug, then your lucky as someone has installed one.
No drain plug, you have to undo all the bolts, yarda, yarda, yarda!
Or try a vacumm pump to remove the oil.
