Extra wide BW diff
_CHOPPER_
, Apr 07 2007 03:36 PM
7 replies to this topic
_CHOPPER_
Posted 07 April 2007 - 03:36 PM
Ideally, I'm looking for a BW diff that's 3" wider ( axle flange to axle flange ) than a VN BW. Somebody want to have a shot in the dark about what might be out there? I can get a housing widened if needed, but that's not my preffered option. Ideally it would also be 28 spline and 4.11 gears, but I think I'm really pushing it there.
Posted 07 April 2007 - 04:51 PM
how wide are the later falcon ones?
Posted 07 April 2007 - 09:28 PM
I might be able to answer that tomorrow.how wide are the later falcon ones?
_CHOPPER_
Posted 07 April 2007 - 10:59 PM
If you mean the EF - EL, about the same width as the VN.how wide are the later falcon ones?
Posted 08 April 2007 - 04:15 PM
NA Fairlane 15mm narrower than VN wagon. Axle flange to axle flange.If you mean the EF - EL, about the same width as the VN.how wide are the later falcon ones?
VN 1555, NA 1540
Edited by rodomo, 08 April 2007 - 04:21 PM.
_on the limit_
Posted 11 April 2007 - 10:24 PM
the new holden crewman diffs are pretty wide, are what about a B A ute diff , i know its a f_rd, but you only want the housing!
_CHOPPER_
Posted 11 April 2007 - 10:38 PM
I couldn't find the rear track spec for the Crewman. I would prefer the Crewman housing, as I plan on running Commodore rear brakes. But I did find it for the BA ute. 1547 mm or 1577 for the RTV version. Now to find a housing at the wreckers...
_CHOPPER_
Posted 11 April 2007 - 10:47 PM
Just Googled Crewman rear track and got a variety of results. Rear track specs range from 1577 mm to 1597 mm. Looks like that should do the trick.
