i updated the generator a vhile ago with a modern unit, forgot to put the dam wire back on from the dash so my little red light goes off, but i forget what colour it is, and where does it go on the new altenator? had a guess and it started making squeeling noises, so better to ask first.
and the oil light does not work because the wire is not plugged in, but just down from the dizzy, i can not see the point where it actually goes on.
"gen" lamp on dash
_gstar_
, Jan 15 2006 10:44 AM
1 reply to this topic
_gstar_
Posted 15 January 2006 - 10:44 AM
_73LJWhiteSL_
Posted 15 January 2006 - 12:54 PM
If you look on this picture, to the right of the oil filter (White) you will see a chrome drum. Thats a oil preasure sender for a guage. In the same place as that there will be a bolt with a pin and a big head on it. The oil wire goes on that.
The bolt is a lot smaller than the drum you see there. This is cause i have the GTR cluster with the oil preasure sender and the sender is different.
Hope i haven't confused you
Steve
Edited by 73LJWhiteSL, 15 January 2006 - 12:58 PM.
