186 steel crank id
Posted 15 April 2007 - 09:38 AM
in theory this should have a steel crank, i have this engine out of the car and on an engine stand, how do i tell if it still has the steel crank? is the a part number or casting mark to look for?
Posted 15 April 2007 - 09:26 PM
they are the same crank and interchangable,
I thought the part number on crank ended in 777 for steel but don't quote me
Posted 15 April 2007 - 09:36 PM
hope this helps
I will check my stel cranks tomorrow and let you know
peter
Posted 16 April 2007 - 09:07 PM
Posted 16 April 2007 - 10:22 PM
ALL Holden 6 cyl cranks (149, 161, 179 & 186) were forged steel up to April 1967 (mid HR). After that only 186 X2, 186 S and LC XU-1 got the forgings all other 6 cranks were nodular cast iron.
Dr Terry.
Posted 17 April 2007 - 08:10 PM
Posted 09 May 2007 - 07:52 PM
_SableMet7/73_
Posted 12 May 2007 - 10:16 PM
Look at the front crank throw between the 1st main to
the 1st rod journal (the unmachined bit) if theres a
thin slightly raised line down the length of the throw
then its cast(casting mould parting line)
Forged cranks have a wide forging mark, about 8/10mm
cheers jono
_192cubes_
Posted 15 May 2007 - 03:52 PM
Sit the crank vertically on a soft surface (bunch of rags will do) and hold it upright with one finger in the depression in the snout of the crank - in other words have minimum contact with the crank.
Now tap one of the counterweights with a small hammer.
If it has a real flat "dong" sound it's cast.
If it has a nice "ding" sound (kinda like you'd get from a bell) it's steel.
Forgings always have better resonance than castings. Don't laugh, it works.
Dave
_oz772_
Posted 01 June 2007 - 05:40 PM
_Drag lc_
Posted 02 June 2007 - 07:40 AM
Thanks Hayden
_oz772_
Posted 02 June 2007 - 12:40 PM
Posted 18 June 2007 - 01:55 PM
finally got into the shed today and the one i have is a 7431320 so that means that i have a steel one correct?i got the part numbers of the ones that i have in the shed they are 7431320 and 7420005 hope this helps.
