bcm bypass
2 replies to this topic
#1 _shmack_1_
_shmack_1_
Posted 18 April 2007 - 02:34 PM
can this be done? and if so how. I am using the vr-vs manual ecu. I will be making a custom dash out of auto meter gauges so any info there will be great to !!
#2 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 18 April 2007 - 08:13 PM
This one might be better handled through PM's I thnk.
#3 Dr Terry
Dr Terry
  • 3,283 posts
Posted 18 April 2007 - 08:55 PM
Hi shmack 1.
I assume you have converted your Torana to 5 litre EFI, using the 082 Delco ECU. If this is the case then, yes, the immobliser system can be by-passed so you don't need a BCM. The mem-cal just has to be re-programmed in the VATS section so it will start without needing the coded signal from the BCM. Most competant chip suppliers/programmers will do this for you.
I don't understand the question about the Autometer gauges, these are not affected by or connected to, the ECU or BCM.
Dr Terry.
