what's the largest rims i can fit under stock hq
8 replies to this topic
#1 _jabba_
_jabba_
Posted 18 April 2007 - 11:49 PM
Just keeping an eye out for wheels for the monaro, but i want to know what width and offset (and what size rubber) i can stick under there without scrubbing with a standard salisbury diff and no body mods (i would roll the lip if needed). Also what size can you safely put under the front without hitting the lip of the guard.
Damien
Edited by jabba, 18 April 2007 - 11:50 PM.
#2 TerrA LX
Posted 18 April 2007 - 11:57 PM
8" rim tyre combo with 4" back spacing works ok, if you could squeeze out a bit more back spacing would be better tho.
#3 _Monkey_
_Monkey_
Posted 18 April 2007 - 11:58 PM
I would like to know this too
also is there any width difference between sedan and wagon rear guards??
I have a 245 rear/215 front in there atm.
#4 TerrA LX
Posted 19 April 2007 - 12:03 AM
^ no but the wheel base is longer.
#5 _CHOPPER_
_CHOPPER_
Posted 19 April 2007 - 09:29 AM
On my HX, I fitted a pair of 15x10 ( - 5 offset ) with 255/60R15's many years ago. Gave the guards a tap in a couple of places and all was cool.
#6 _MYLJ_
_MYLJ_
Posted 19 April 2007 - 09:30 AM
I was running 275/50/15 tyres on 8 inch rims with a 4 inch backspacing on the wagon, without shortening the diff but with the lips rolled on the guards.
currently running 295/50/15's on 9inch rims with 3 inch backspacing, but the diff is 2 inches shorter than standard and the wheel arches are pumped out about an inch too :D
can't help you much with the fronts as I use front runners, but we used to fit a 225/60/14 under the front of the HQ race car on a 7 inch rim.
Wagon and sedan do have the same width wheel arch area but but they are different shapes inside the wheel tub , the wagons r/h/s inside wheel tub is longer to allow for the fuel filler neck too.
#7 MRLXSS
  • 12,415 posts
Posted 19 April 2007 - 01:30 PM
Currently on my Hq i got Widened Hq stockies that are 14X8. not sure of the Offset but 235/50/14 fill out my guards perfectly, like it looks like it would rub, but it never has even with a car full of people!
#8 _jabba_
_jabba_
Posted 19 April 2007 - 02:07 PM
Good info, keep it coming :spoton:.
One more question, what is the smallest rubber and largest rubber that will (safely) strech over *x8 *x9 and *x10 rims. I want to fit largest rims i can, rather than using really wide rubber on a smaller rim if its possible.
#9 TerrA LX
Posted 19 April 2007 - 09:06 PM
^ see sticky's http://www.gmh-toran...hp?showforum=13
