hey guys yesterday i got my tranny off my mate which came out of a VS clubsport .... he sayz its a 4spd T/700... but just wanted to check with you guys b4 i hand the money over...
some of the numbers on the box are (8642547) which is located at the start of the box were the tailetshaft slots into....
and....
54 in large numbers on either side.... and M30 on one side of the bellhousing
cheers guys
turbo 700
_1TUFSLR_
, May 04 2007 01:56 PM
7 replies to this topic
_1TUFSLR_
Posted 04 May 2007 - 01:56 PM
Posted 04 May 2007 - 02:22 PM
Hi 1TUFSLR.
The auto you need is the TH700 otherwise known as a 4L60. They were fitted to VN/VP/VU/VQ Commodore and their relatives. The auto trans out of a VS V8 is a derivative of the 4L60, called the 4L60-E. It is electronically controlled & is therefore not suitable for your application unless you are also fitting the VS V8 engine and computer to match. The easy way to pick if it is the electronic one (or not) is to look on the driver's side of the box. If it has a kickdown cable it is a TH700/4L60 box, the one you DO want. If it has a round electrical connector with lots of pins. it is the electronic box, this is the one you DON'T want.
Dr Terry.
Dr Terry.
_1TUFSLR_
Posted 04 May 2007 - 03:18 PM
dr terry ur a champ
.... i jus rang up my gearbox bulider and he said the same thing you said soo lucky i asked
.........they got me one out of a VN for 400 i gta pik it up on monday sooo worked out better for me
Posted 04 May 2007 - 03:50 PM
Hi 1TUFSLR.
Be careful at the wrecker, because there a 2 types of TH700, V6 & V8. $400 sounds too cheap to be a V8. You have said what type of car it's going into, but the V8 one is sought after for V8 conversions.
A typical wrecker price in Sydney is over $1000 fot a VN/VP V8 TH700.
Dr Terry.
Dr Terry.
_lj chev_
Posted 09 May 2007 - 11:57 AM
before buying from wrekers check commodore sites as 1,000 is expensive as for a s/h 700.
_1TUFSLR_
Posted 09 May 2007 - 11:24 PM
i ended up payin 400 for mine... from the guy dat is building it for me
_lj chev_
Posted 10 May 2007 - 09:18 PM
thats allright
what are you getting done to it?
_1TUFSLR_
Posted 12 May 2007 - 03:22 PM
Lj chev i got the recipt in front of me so this is what i am geting done to it in bout a month or more saving seein im only 20 lol.......
its getn :
stage 2 shift kit
corvette billet servo piston
raybestos clutches
4800 stall
modified drums and pump
transcoolers
its pritty much getn built to support my 355 thats also in prgress ...which should have about 450-500 hp when finished
its getn :
stage 2 shift kit
raybestos clutches
4800 stall
transcoolers
