253 / 308 heads
24 replies to this topic
#1 _slr253_
_slr253_
Posted 12 May 2007 - 09:17 PM
Hi,
Are the cylinder heads for a 308 the same for a 253? I have a 253 and there are a lot of worked 308 heads for sale. Will 308 heads fit onto a 253?
Cheers,
Brett
#2 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 13 May 2007 - 08:34 AM
the same
#3 TerrA LX
Posted 13 May 2007 - 03:43 PM
All 253's are standard (read small) valve heads, some 308 and worked 308 heads have large valves where the inlet head actually sits over the bore on a 253, problems are valve shrouding and on high lift applications the valve can actually hit the block.
otherwise they are same same.
#4 _slr253_
_slr253_
Posted 16 May 2007 - 08:50 PM
Thanks for the info.
Cheers,
Brett
#5 _JBM_
_JBM_
Posted 17 May 2007 - 11:26 AM
This is why VN heads cant be fitted to a 253, even though the bores are 5 mm different in diameter.
James
#6 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 17 May 2007 - 02:04 PM
Sorry James, VN heads can be successfully fitted to 253's (ask Herne !!).
You would need well over 0.500" lift before the valves even looked close to hitting the block, even then you could relieve the block in the valve area, just like any Clevo or BBC.
#7 _JBM_
_JBM_
Posted 17 May 2007 - 04:44 PM
Thats good to know if I need 400HP+ from a 253. ;)
I wonder how my 253 VH would go with the L34 heads, single plane manifold and Carter 4bl from the SL/R.
James
#8 TerrA LX
Posted 17 May 2007 - 07:16 PM
Before you even get to 500th lift you still have the disadvantage of the bore cutting into the cone that is formed behind the head of the inlet valve, something relieving the top of the bore for valve clearence will not rectify, you need a minium of a 4" bore for the large valve set up to function correctly.
I am not saying the set up wont work because even a side valve ford works.
#9 mr5000
mr5000
    chief break-everything
  • 3,456 posts
  • Car:77 lx 4door
Posted 17 May 2007 - 07:24 PM
ive been working away at my heads at the moment on the 253 port polish and match ported with the intake the exhuast was already spot on getting the valves and guides re done ill let you now how it goes once in
#10 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 18 May 2007 - 08:18 AM
The difference in flow from a 3.625 bore to a 4.000 is not as great as you might think. I am not saying there isn't a difference, but in the real world it hardly matters.
You are assuming that air and fuel flows over the valve in a conical pattern. One day if your've got nothing better to do get a garden vac. and silicon it to the head face as if the barrel of the vacuum was the bore of the engine. Turn on the vac, crack a valve open at about 0.250" and spray some paint at the intake port. The resultant spray pattern will show you exactly where air and fuel flows through the port and out past the valve. All is not as it seems.
A 4V Clevo intake hangs well over a 4" bore (a lot further than a 1.94 on a 3.625 bore), yet they still work well.
Saying that you need a 4" bore for a 1.94" valve to work properly....... I guess we will have to disagree. The difference in flow would be in the order of 2.5 to 3%.
Fit your big valve heads to your 253 and rev it up. They need the airspeed.
JMHO
#11 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 18 May 2007 - 08:29 AM
I must apologize to ALX76 if you think I am having a go at you. I'm not.
#12 TerrA LX
Posted 18 May 2007 - 06:23 PM
No need to apologize, this is an open public forum there is no personal attack here just differences of opinion.
I never said it wont work, just not as good. i just cant understand when for 50 (or more) extra cubes adds up to 50 or more horsepower.
#13 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 18 May 2007 - 06:34 PM
It doesn't.
Generally peak power is close to the same, torque however is a different story. The smaller engine will also need more rpm to make the power, but it will make it. The larger engine, having more torque, will also move a vehicle quicker. Herne's 253 with the VN heads made 100kw at the tyres, this is exactly the same as a standard VN/VP. The only difference is the cubic inches. The 304 however does peak a lot earlier.
#14 TerrA LX
Posted 18 May 2007 - 08:55 PM
bout the same horsepower you would get from standard valve heads with a 465 holley.
I see where you are going tho, with the right heads/cam you could get 600Hp from a 253 at 12 000rpm. :tease:
#15 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 03 June 2013 - 09:27 PM
I found this thread by doing a Google search, so I thought I'd ask a couple of questions.
Firstly I will assume that is lift at the valve, not the cam? And if the bore is taken out to the figures quoted in the following thread:
http://www.gmh-toran...troker-options/
Then that would give more scope for more lift?
Stock 253 bore is 3.625"
Stock 305 SBC bore is 3.736"
030 over 305 bore is 3.766"
To get the right deck height with a 253 mini stroker you need to use the 305 piston which neccesitates the 0.110" to 0.140" overbore. Like I have said before, the 253 has really thick cylinder walls and can easily accomodate this sort of overbore.
FWIW a standard 305 SBC has a stroke of 3.48" so using a 355 crank in a 253 with the 305 pistons will net 305 cibic inches, a 030" overbore will lift it to 308 CI. The 305 pistons will need to have the tops trimmed down to remain level with the deck with this much stroke.
Hope this helps.
But if I go the above route with the 3.48" crank and zero deck height, would the problem then be piston to valve clearance?
PLEASE NOTE!
The maximum intended revs will be 6000 - 6500, so maybe a bigger cam won't be needed? Fuel will be 98 octane.
#16 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 04 June 2013 - 08:54 AM
Way to go thread miner !!!
Yes, that is lift at the valve.
I have never run into piston to valve clearance issues with a 253/308 and have run in excess of 0.600" lift.
The stroke will not affect the PTV clearance (in this case).
I just measured a stock 253/308 head. The valve sits 0.400" below the deck face. Add a head gasket and deck clearance and there is heaps of room. I have had a head on a 253 block and looked up from the crank side, the stock valves clear the bore. You may have to relieve the deck on the intake side a little if you use a 1.94" valve. It won't be much. With the 305 bore it will probably clear. Worth checking during assembly though !
Seriously, if your spending this much on a 253 then the extra $300 odd to upgrade to a 4" bore block (304/308) is really well spent.
Hope this helps.
#17 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 05 June 2013 - 09:05 PM
Thread miner? My grand kids simply taught me how to use Google. You mentioned using a 1.94" valve. I intend on using the stock sized valves, so it looks like everything will clear OK. And as for using a 308, I have a spare Trimatic 308 block a couple of feet away from the telly. But it's an all matching numbers car, so the 253 has to stay.
#18 _qiksix_
_qiksix_
Posted 05 June 2013 - 11:20 PM
While i thinking of it are all 304 blocks turbo pattern, looking at replacing a 308 in a boat.
#19 _Quagmire_
_Quagmire_
Posted 06 June 2013 - 02:07 AM
yes..but re-drilling the block to suit either pattern g/box is a cheap exercise these days
don't even think of using adaptor plates
#20 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 06 June 2013 - 01:02 PM
You can also get bellhousings that are turbo pattern - trimatic, I think Dellow make them....
#21 _Quagmire_
_Quagmire_
Posted 06 June 2013 - 01:19 PM
yep but last heard these where around the 300 mark...drilling was less than a hunge...
#22 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 06 June 2013 - 10:14 PM
CRS have bell housings as well and it wasn't cheap, i think it was about $500 for the bell housing alone
Quag, i rang an engineering shop in Mackay, they hadn't done one before but would have a go at it, they were going to charge me around $400 to do the job, thank frOck i found a complete tri-matic engine.
Edited by Mort, 06 June 2013 - 10:15 PM.
#23 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 08 June 2013 - 09:49 AM
This post might be a bit of useless information but I think its worth a mention.
The 253 in my opinion is a humble,honest little engine,although they often get ditched for something bigger,bit like starfires.
The one my Mrs had in Her little sunbird had big valves fitted and a very small cam with a  Roty. carb.
My stock other than 40th overbore in my LH with a Strommy would leave Hers for dead,with an auto.
Thats not the only case,a neighbour of mine has the same set up as my Mrs had in His tonner,same deal, my stocker
would leave the thing for dead,and the tonner would only just pull away from my starfired UC,I drove all cars so am not dreaming about the performance.
Point being,the 253 does not seem to like the big cam/valve combo.so leave the valve size well alone,stick with stock valves or if you have the time and money fit slightley smaller valves.
Another point worth considering if anyone is playing with the 253 is the head gaskets.The 253 head gasket is not or shouldnt be the same as the 308 despite what they tell you on the packet or at the parts shop.
Obviously the 253 has a smaller bore than 308 so a correct size head gasket is a must,if you can find the metal ones fitted on some of
the early 253's they can be used with some of the good sealants these days,they were prone to leak,but I doubt very much if you will find a set.
ACL make a head gasket for the 253. http://www.aclperfor...siteGaskets.htm
#24 rexy
rexy
  • 3,768 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 08 June 2013 - 02:29 PM
Done by a reputable business will be a lot more.
Harrop will do it well in Melbourne. $370 eighteen months ago.
#25 _Lazarus_
_Lazarus_
Posted 14 June 2013 - 11:23 AM
Pre-pollution 253 is 185 HP, pollution is 171 HP and Blue is 150, if I have remembered correctly.
I have an early one in a HZ. Plastic 4 blade fan, 350 Holley, extractors and a good exhaust system, HE sump and hi vol oil pump, otherwise standard with a Traumatic. I had a TQ30 in it for a while but took it out to see if it would improve fuel consumption. It did, but probably mainly because I had got bad advice when we installed it, to retard the cam.
I love that motor, super reliable and great for highway cruising. I drove it from Bundy to Cairns one time with a 2.78:1 diff and got better than 10 litres per 100k. I had to keep rechecking my calculations to make sure I wasn't dreaming.
The last couple of years it was registered I had a 3.36:1 in it and it was much thirstier.
The Commodore Cup cars used the YT Hi-Torque heads with about a 1.85 valve didn't they ? They were getting up to around 380 HP on early rods. Plenty of grunt for a street motor IMO.
