gidday all,i've been told you can cover acrylic with two pack clear,has anyone tried it,and what do u think.thanks rob
two pack clear over acrylic
lcgtrrob
, Jun 03 2007 10:19 AM
6 replies to this topic
Posted 03 June 2007 - 10:19 AM
Posted 03 June 2007 - 10:26 AM
Ive done 2k solid over acrylic and you get away with it if the acrylic is totally dry (and i don't mean three weeks in the shed dry), but would not recommend it for total resprays.
Posted 03 June 2007 - 10:40 AM
thanks alx76,when you paint two pack do you go back to bare metal or is there some sort of undercoat/sealer you can spray over acrylic-rob
_Pete_
Posted 03 June 2007 - 11:19 AM
Painting twopack over acrylic is not a recommended process, You might get away with it in the short term but regardless on how old or new the acrylic paint will be there will always be a good chance of the new twopack paint work "sinking" in and around the old acrylic, leaving you with unsightly marks in the paintwork and/or crazing.
If your going to paint 2pack clear over acrylic basecoat you may as well use 2pack basecoat, there wouldn't be much difference in cost or application and at least you know it will work together.
There are products available to use as a sealer between old paint and new, We use one at work which is a Glasurit product but I can't remember their brand's name of it, we just call it by the old PPG slang name of "Scan Sealer", it is a 2pack transparent sealer.
Obviously with all paintwork the more stable the surface to be painted the more chance your new paintwork will look its best, therefore a Bare metal surface is the optimum.
Posted 03 June 2007 - 05:44 PM
thanks for the replies pete and ALX76 you've saved me a lot of time and money experimenting thanks -Rob.
_Squarepants_
Posted 03 June 2007 - 06:26 PM
My panel beater (like I own him at the moment!?!) uses an epoxy (plastic) primer to seal bare metal before he applies any filler. He also applied it over the bits that had old paint and primer still on it. He reckons it seals everything and stops sinking etc. It's a pale green colour but I don't know what brand it is or what it's called. I can find out if you're interested.
Edited by Squarepants, 03 June 2007 - 06:29 PM.
Posted 04 June 2007 - 04:40 PM
thanks squarepants,that would be good,when u see him next i'm in no hurry,thanks again.
