urethane bushes or rubber?
_shmack_1_
Posted 03 June 2007 - 04:05 PM
_JBird_
Posted 03 June 2007 - 04:08 PM
I put Urethane bushes in mine (LJ) and it's always at the back of my minds if they start to crack or something.
If you insist on using urethane, go for Noltec bushes. And don't rig your diff/trailing arms up with urethane, or the front end mounts. Uppers/Lower control arms with Noltec should be alright though. About the only place where not having any movement in the suspension would be the Radius Rods as that helps with braking straighter.
_youngy_11_
Posted 03 June 2007 - 06:05 PM
It will be alright
_Squarepants_
Posted 04 June 2007 - 11:30 PM
If you're going to replace all bushes with polyurethane you will have a much harsher ride and get alot more vibration and noise in the car, aswell.
_JBird_
Posted 04 June 2007 - 11:47 PM
Urethane you need constant checking. Over bumpy roads the urethane squeaks like you have mice in your dashboard.
_Chamois hatch_
Posted 16 June 2007 - 11:54 AM
Posted 17 June 2007 - 07:02 PM
the torry steers really well and never had a problem in the 3 years its been on the road.
_Barman_
Posted 19 June 2007 - 05:59 PM
Baz
Posted 19 June 2007 - 06:12 PM
_timbotorrie_
Posted 22 June 2007 - 09:22 PM
Posted 23 June 2007 - 01:40 AM
_Squarepants_
Posted 25 June 2007 - 04:36 PM
As opposed to rubber bushes that actually flex with the suspension movement, poly bushes allow the "pin" (centre spigot that goes through the bush) to pivot inside the bush. This is why some (I'm not sure if this is the case on any torana bushes) come with steel sleeves through the centre hole, so you tighten the component onto the sleeve, rather than the bush itself, the bush then pivots on the sleeve, rather than flexing like a rubber item.
This is also the reason they wore my steel UCA pivot arm out (they had no sleeve).
This is also the reason that you shouldn't tighten rubber bush mounts whilst the car is jacked up, rather you should leave them loose, drop the car down and then tighten them up at it's normal ride height, otherwise, if you tighten them whilst jacked up and the suspension all hanging down, they will flex and be stressed when you put the car back down on the ground, where the suspension normally sits.
_Brewster_
Posted 08 July 2007 - 03:35 PM
Does using nolathane bushes on the outriggers to the body create vibration? Or should normal rubber bushes be used for that?
Posted 11 July 2007 - 10:07 AM
Posted 11 July 2007 - 12:49 PM
Posted 11 July 2007 - 12:56 PM
_Brewster_
Posted 11 July 2007 - 02:35 PM
_gmhgtr_
Posted 11 July 2007 - 04:40 PM
gmhgtr
Posted 12 July 2007 - 07:36 AM
Posted 12 July 2007 - 09:56 AM
A) your too old!
in all seriousness i have had my LJ together for 3 years and have no squeacks in my suspension and i have nolathane all round. If they are correctly lubrucated and fitted then they are better then rubber, yes it firmens the ride, but thats the point. rubber tends to harden over time, and also seems to crack. its really a personal choice
#21
_Brewster_
Posted 12 July 2007 - 01:04 PM
I really wanted to use nolathane, for two reasons,
1. Firms up the ride, although I wont be using the car for racing and
2. Because the car has to go in for rego checks, I get sick of the inspector sayin, these rubber bushes are cracked and need replacing when the seem fine
#22
_JBird_
Posted 12 July 2007 - 01:37 PM
Every time I go over a pothole the whole car crashes and over bumpy roads it makes my dash squeak. So the Noltec ones don't squeak...it's my dashboard. It does make the car feel like one though and I would recommend it...though if I was to do it again I'd go all rubber as Chopper/Dr Terry have recommended me before.
I would also go rubber steering coupling cause with the Noltec coupling the bolts that hold it aren't long enough to reach the nylock part.
James
#23
Posted 12 July 2007 - 06:58 PM
The upper control arm ones do not move freely enough in my opinion either.
weather you use them in the lower control arms is a matter of personal choice.
I don't think they feel too harsh but I am always nipping up the bolts in the dash as they like to loosen off and rattle a little bit which annoys me.
I would definately not use polyurethane in the rear upper control arm mounts
Not only do the poly ones split if you use them in your rear upper control arms (and drive the way I do) - I can show some good pictures, but they make the weight transfer on the rear end worse than it already is and will not help handling.
M@
#24
_Brewster_
Posted 12 July 2007 - 07:48 PM
