What manifolds available for Holden 308
17 replies to this topic
#1 LS1LX
LS1LX
  • 1,931 posts
Posted 20 June 2007 - 07:14 PM
Need to get a manifold for early RED heads, been looking and there is Edelbrock Performer & Torker, Redline Hi-Winder and I think Harrop makes one as well.
Engine is 10:1 flat top 308, solid camshaft 240/240, L34 heads ported, roller rockers etc.
I really want to keep it under standard bonnet as well, no scoops
Have been leaning towards a Performer and adding a spacer if its holding back top end.
Car is 4 speed manual with 3.55:1 rear, just a streeter.
#2 _v8slrtorana_
_v8slrtorana_
Posted 20 June 2007 - 07:31 PM
I don't think Redline Hi-Winder is avliable for a red, only VN style. Could be wrong.
Here is a few more to think about.
-Procrap have a new stripmaster look a like.
-The Peter Michaels Stripmaster
-Duggan, rare and no longer made
-Weiand Excellerator (I have one, not as good as the Duggan, but better the other low rise single plains, also no longer made)
-LYNX, same casting as Weiand
-Torque Power (Good luck trying to get him to sell you one for a 308, they are more designed for a 355 or 383, and are a high port manifold suit YT Dash 3 heads)
-Brain freeze now :fool:
#3 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 20 June 2007 - 07:53 PM
FYI years ago I had a Weiand Accelerator and my car ran 12.60 every day. I pulled it off and refitted a stock HQ manifold with a squarebore adapter. The next time out it ran 12.2. No other changes.
For your combo you can't go past a Performer. more torque than the Torquer everywhere and same HP with the right spacer.
#4 _BoltZ_
_BoltZ_
Posted 20 June 2007 - 07:58 PM
Go the stripmaster :spoton:
#5 _1QUICK LJ_
_1QUICK LJ_
Posted 21 June 2007 - 01:30 AM
wow that an interesting result, i guess theres no substitute for trial and error, i have a stripmaster but i will be trying a few different manifolds just in case.
#6 _maxpower1000hp_
_maxpower1000hp_
Posted 21 June 2007 - 04:16 PM
Gday mate, if you still looking for a manifold l have a Edelbrock performer
that would be perfect for your motor if you interested you can get me at
[email protected]
#7 LS1LX
LS1LX
  • 1,931 posts
Posted 21 June 2007 - 08:01 PM
Email sent thanks
#8 _SLR Goat_
_SLR Goat_
Posted 21 June 2007 - 08:19 PM
Edelbrock torker should still fit your carby and air cleaner etc under the bonnet but it is a mid range to high rpm manifold wereas the performer is a more of a down low to mid rpm manifold i cant recall the exact rpm range they specify of hand
#9 _big_als_army_
_big_als_army_
Posted 02 July 2007 - 10:10 PM
Torker is single plane and Performer is dual plane, thats the main difference so the Torker is designed for the higher rev range whereas the Performer will perform well right through the range with a bit of a sacrifice up top
#10 _[BOTTLEDUP]_
_[BOTTLEDUP]_
Posted 04 July 2007 - 05:29 PM
Anything up to 400hp on a 308 I say stick with the Performer... Add a 1" phenolic spacer if necessary.
#11 LS1LX
LS1LX
  • 1,931 posts
Posted 06 July 2007 - 09:21 PM
Cheers all, actually brought a new Performer last Friday.
Thats my plan run the performer and if need be add a spacer for a little top end, well see how it goes. :rockon:
#12 _1BADSS_
_1BADSS_
Posted 04 August 2007 - 09:48 AM
How did the Performer go on your combo, much of a difference in the power?
#13 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 04 August 2007 - 11:19 AM
a bit of a thread steal, what are the duggan manifolds like? I might be able to get my hands on 1
#14 _1QUICK LJ_
_1QUICK LJ_
Posted 05 August 2007 - 09:06 PM
ive heard good things about the duggans but have never used one myself.
#15 _v8slrtorana_
_v8slrtorana_
Posted 05 August 2007 - 10:41 PM
i can get photos of a duggan if need be, my mate has one under his bed.
#16 _SS Hatchback_
_SS Hatchback_
Posted 07 August 2007 - 10:34 PM
hahaha sounds like something i would do, when i bought my barry grant carb it sat on my bedside table for 2 weeks before i installed it , misses wasnt to impressed though
#17 _v8slrtorana_
_v8slrtorana_
Posted 07 August 2007 - 11:53 PM
My mates car is getting near the end of a 15 year rebuild, most of the car is still in his room :D
#18 _Monkey_
_Monkey_
Posted 08 August 2007 - 12:03 AM
I've got every single part for a 355 under my bed, minus the block of course :D
