fuel lines
_superlowuc_
Posted 23 January 2006 - 04:51 AM
It looks pretty easy but before I start I thought someone out there would have done it before and was wondering if there was anything that I would have to watch out for or any potentail problems I should be aware of?
The car will be set up for a blow though system so Will my stock fuel pump be ok? and what about a surge tank is it a good idea? ( car was a 4 bagger to begin with)
I Do not want to light my car on fire with a gas leak!! so I want to do it right
cheers guys as alway your help a great resource as this is all a learning curve for me
antony
Posted 23 January 2006 - 06:40 AM
RACV MAN
_superlowuc_
Posted 23 January 2006 - 12:14 PM
cheers antony
Posted 23 January 2006 - 06:05 PM
Comes on a coil, PBR makes it.
Remember to flare you fuel line ends or use high quality compression fittings.
You will need the charcoal canister for Emission and rego purposes unless its a non street registered vehicle. Or in NZ?
_superlowuc_
Posted 24 January 2006 - 12:10 AM
Posted 24 January 2006 - 07:00 PM
believe it or not i've been researching this for a while now...
_1QUICK LJ_
Posted 25 January 2006 - 07:45 PM
_CHOPPER_
Posted 25 January 2006 - 08:03 PM
Posted 25 January 2006 - 08:13 PM
Cracks from vibration. It is illegal on every state road in Australia.Copper is also a no-no for brake lines and probably for the same reason. Mind you, I can't remember what.
Steel is about $20 more to do a car then copper, why risk it to save $20 put your safety and others at risk.
_CHOPPER_
Posted 25 January 2006 - 08:16 PM
_Jewboy_
Posted 25 January 2006 - 10:25 PM
Posted 26 January 2006 - 07:58 AM
There nothing wrong with aluminium, especially the russel stuf, as long as its annealed, only problem is I tried aluminium on my car as it was $8 for 6metres, but I needed a few 90 degree bends and the tube was very easy to crush/kink. I turfed the stuff for steel, steel was $65-75 for 6metre roll but well worth it for the added safety.I don't know whats wrong with alloy one, mine went over the pits fine only had to upgrade mounting hardware (zip ties weren't good enough - go figure). I believe there is some folded tubing which is what you don't want. I used Russel alloy tubing on my car. Only reason why not to use alloy is if you were going to use methanol.
Did the anodising scratch off the russel tube when bent?
_Jewboy_
Posted 26 January 2006 - 10:14 AM
_CHOPPER_
Posted 26 January 2006 - 11:22 AM
_MYLJ_
Posted 26 January 2006 - 11:54 AM
If there is a good reason why you shouldn't use copper for a fuel line let me know what it is, as I'll change it if there is a good reason. The only thing I had thought of was that the copper may break down due to all the wierd stuff in unleaded fuel, anyone have any thoughts on this?
Posted 26 January 2006 - 04:27 PM
Call the RTA if you want there explanation, we dont make the rules we just try obid by them. Sorry.I've been using a 1/2 inch copper line for 15 years for the fuel line, never had a problem, never had it crack and the car has plenty of vibration, it is well attatched with rubber inserted stainless steel clamps every 2ft or so, it was cheap and easy.
_1QUICK LJ_
Posted 27 January 2006 - 12:59 AM
_superlowuc_
Posted 27 January 2006 - 02:25 AM
thanks again
antony
_CHOPPER_
Posted 27 January 2006 - 09:08 PM
_superlowuc_
Posted 28 January 2006 - 04:14 AM
cheers antony
#21
Posted 28 January 2006 - 02:15 PM
#22
_superlowuc_
Posted 29 January 2006 - 03:49 AM
cheers antony
#23
_MAWLER_
Posted 31 January 2006 - 06:21 PM
#24
_Torana482HP_
Posted 31 January 2006 - 06:57 PM
i need to replace mine cause its not big enough but i dont know if i should go 3/8 or 1/2.
#25
_CHOPPER_
Posted 31 January 2006 - 10:23 PM
