holden v8 wont rev hard...
_@milco@_
Posted 25 June 2007 - 09:34 PM
i am having a problemwith my 253 where it will not rev over 4 grand, the motor has been completely rebuilt, has a mild cam, Yella Terra spec heads just machined up and put on, holden 4 barrel manifold, brand new rebuilt quaddie
all these things are garrented
my only issue is that i got a "rebuilt trimatic" well thats what the guy told me ( sort of mate trust worthy tho) the trimatic shifts fine and does not seem to slip, i was just wondering what would be a possible factor in it not reving...
i was thinking stall converter might be a issue, is it possible?
the trimatic appered to be in very good nick as i was told fluid was nice red color not burnt. the car will chirp shifting from first to second no problems.
car is running a 3.36 diff could this be the issue?
this is my first auto torrie the rest have been manual, ( i am kinda kicking my self now should have gone manual.....)
help!
Posted 25 June 2007 - 09:47 PM
Posted 25 June 2007 - 09:53 PM
_@milco@_
Posted 25 June 2007 - 10:13 PM
yeah thought so, just had a slight thought that it might be a gearing issue.... ok so nit the diff....diff wont stop it from revving...look elsewhere.
i have had two electronic dissy in the car same thing both cam out off fine cars perfect working order, so i doubt it's spark.
mm what else, i am leaning towards a gearbox/convertor issue but i dont know much about it at all, and i dont want to fork out the cash to get the convertor replaced and then have the same issue, just thought somone on here might be a bit more cluey about trimatic set ups...
Posted 25 June 2007 - 10:20 PM
_@milco@_
Posted 25 June 2007 - 10:38 PM
timing is about 11-12deg adv,
brand new fuel pump
brand new fuel filter
genie extractors, new 2 1/2 inche twin pipe system with cross over pipe
dont know how to check float level of a quaddie
( quaddie was complete ly rebuilt buy a carby shop in melb, he also and tuned it as well)
i think it is getting a bit to much fuel and it's running slightly rich....
new leads
new plugs...
i am a bit suspect on the tune
also it's a fresh motor just been rebuilt, i have only put about 500-700km on if that............
_Squarepants_
Posted 25 June 2007 - 10:39 PM
_@milco@_
Posted 25 June 2007 - 10:48 PM
mmmmm never thought of that....... might have to do that..... thanksCheck the operation of the mechanical advance in the dizzy. I know a dude who had a similar problem, turned out his dizzy shaft was seizing up.
_Jewboy_
Posted 25 June 2007 - 11:37 PM
_JBM_
Posted 25 June 2007 - 11:43 PM
Check the static timing on No 1 cylinder.
James
Posted 26 June 2007 - 12:35 AM
_@milco@_
Posted 26 June 2007 - 08:13 AM
at 4grand it just will not rev anymore... does not missfire or backfire at all
_mumbo_
Posted 26 June 2007 - 08:47 AM
Posted 26 June 2007 - 09:04 AM
x2Valve springs?
Posted 26 June 2007 - 09:32 AM
the motor?completely rebuilt
Id be looking at spring and cam timing.
_@milco@_
Posted 26 June 2007 - 10:43 AM
Posted 26 June 2007 - 10:50 AM
If the springs are that soft you would probably be able to compress them with your hands.
Dont forget to start with the easy things like dizzy and coil.
_@milco@_
Posted 26 June 2007 - 11:29 AM
i have checked all the easys stuff , thats why i am asking you blokes!
thanks so much guys any more ideas are welcome.
i will check the valve springs and go from there....
_dave720gtr_
Posted 26 June 2007 - 01:10 PM
it had them stuffed
Well my friend was the mecanic for this guy who traded it and he stuffed around with it for a some time before thay put in up on the host and my mate grabed the gass axe and chopped the pipes off
it went straight too 7000rpm had a blocked muffler from factory
Edited by dave720gtr, 26 June 2007 - 01:13 PM.
Posted 28 June 2007 - 10:47 PM
http://www.gmh-toran...showtopic=15006
look at senario 9, 10, 11 and 14 for an idea.
Edited by ALX76, 28 June 2007 - 10:50 PM.
#21
Posted 28 June 2007 - 11:34 PM
for f*cks sake, your around the corner from danny, let him have a look at it,
just remember to tell him i sent you
mick
Edited by YiriSS, 28 June 2007 - 11:35 PM.
