Head Numbers
_LJcaruso_
Posted 28 June 2007 - 01:55 PM
just wanted to ask abhout a couple of head numbers......the head i got on there now i ainbt to sure what head it is the number is 7420081 (it also say along that side a224 and has a P) it revs to about 5500 granand was topld tis a stage 3 YT head..........if anyone can tell me that would be good
I got anopther head sitting in the garage with the numbers 2811930 (it also has on the side of the head M52 and has a L) i was told that was astage three YT head but if anyone can verify the two numbers i have given that would be a big help and save me alot of cash swapping and doing up heads! lol
cheers guys,
Adam
_sunburst_metalic_
Posted 28 June 2007 - 03:10 PM
Posted 28 June 2007 - 05:05 PM
As the others said cast numbers wont tell if its YT or not...only port work, valves and springs....but it may just be a stocker modified with large valves, double springs and big ports...and at the end of the day they do the same thing.
_LJcaruso_
Posted 28 June 2007 - 05:08 PM
_LJcaruso_
Posted 28 June 2007 - 05:28 PM
well im waiting to see what heaad i got first becasue im puttin my triple su's on this weekend and then wanna go with a 35/75 solid...... if i put one of them in i gotta play with one headso can match valve springs, ports etc to the cam i want! soo i dunnoe yet..... but do agree with you..they all do the same thing!LoneOranger was after a 2811930 head...a while ago now. PM him and see if he still needs one.
_tuffgong_
Posted 28 June 2007 - 05:45 PM
cheers john
_big_als_army_
Posted 28 June 2007 - 11:00 PM
Posted 29 June 2007 - 12:51 AM
Big als army...yes "L" is low comp
but then according to this:
http://www.gmh-toran...u1 head numbers
Its is right for an LJ GTR..numbers gurus?
Edited by FastEHHolden, 29 June 2007 - 12:56 AM.
_big_als_army_
Posted 29 June 2007 - 12:55 PM
They probably used this cast number head on all 202's from LJ's with factory 202's as they were all JL prefix blocks, not just the GTR's.
_LJcaruso_
Posted 29 June 2007 - 01:55 PM
If it was a GTR head wouldn't it be a high comp head??? would it have better performance wise then a stage 3 YT head??mate, the 2811930 head is a lj gtr head, built on the 5 of the 12 72 so it could be worth a nice little penny to the right person.
cheers john
and If it were sold....what would it be worth????
_LJcaruso_
Posted 29 June 2007 - 02:05 PM
_LJcaruso_
Posted 29 June 2007 - 02:06 PM
Posted 29 June 2007 - 05:00 PM
Wasn't a GTR engine just a stocker?
_big_als_army_
Posted 29 June 2007 - 06:14 PM
Apart from the Bathurst XU-1 heads, the standard XU-1 heads I thought were just the same as any other 202 head too, just with a different casting number then same as this seems to be with these GTR heads.
_SableMet7/73_
Posted 30 June 2007 - 07:04 PM
facing or does it mean the equipment ( screw-in studs & guide plates) ontop
of the machine work ie;stage 1-portng,facing,valves then stage 2-as stage 1
plus studs & guide plates? Havnt seen YT head for a while but got a Hi comp
9937263 '79 head, YT valves, screw-in studs,guide plates,ports cleaned up
& valve pockets relieved & squared off ports at flange.
Also have 9 port converted to 12 port by local Perth head bloke(used to be around
in the late 70s early 80s) named Luigi, 9937263 '73 Hi comp same work as above
plus .050" more shaved off face, huge exhaust ports, intake ports sort of like
Hi riser type shape & chambers have the kidney shape bump machined to a
flat edge or wall & lots of die grinder work in the bowels & runners- this 1 is
definately not good around town( too big) I dont think this 1 is YT. Oh & also
has possibly V8 springs & retainers.
Whats a 9937263 Hi comp head off?
Cheers Jono
