202 Performance upgrades
_dannylxss_
Posted 09 July 2007 - 12:22 PM
I have just purchased a uc with a red 202 engine number starts with VL, The guy i brought it off believes it has a cam, spec ?,
I am going to use the car for Autocross and the odd short rally, now i want to know what performance upgrades i should do, i has a 4 speed MC6 manual, apart from cam, extractors and electric ignition everything else is standard as far as i know.
I am in the western side of melb
any suggestions would be great, i am tossing up between a 350 holley or su's also a yella terra head.
Posted 09 July 2007 - 12:56 PM
Then get some kinda aftermarket 9-Port manifold and a decent carbie setup for it. WW Stromberg for mildish but much better than stock, Varijet for economy and similar performance, triples for more performance and worse economy etc.
Lots of options...
Edited by Heath, 09 July 2007 - 12:57 PM.
_2X044_
Posted 09 July 2007 - 02:44 PM
If you've got a blue motor and want to stick with it you have a 12 port head and may require some different performance orientated equipment to the red. If you have a blue motor I would recommend a fuel injected motor borrowing some of the gear from a VK 202... Expensive way to go about it though.
On a side note blue motors were built to adhere to ADR27C, therefore to be 100% legal continuing compliance with this standard must be maintained (ruling out things like 350 holleys for all intents and purposes), most people however don't care and most don't get caught.
If I have made any mistakes anyone please feel free to correct me.
Good luck
_dannylxss_
Posted 09 July 2007 - 03:46 PM
how can i tell a 9port head from a 12 port head
_willo_
Posted 09 July 2007 - 04:07 PM
of course it has a cam...if it didn't then the bloody valves wouldn't open now would they??The guy i brought it off believes it has a cam
Posted 09 July 2007 - 05:15 PM
Lots of things you can do to get this thing hammering, first things first, how much $$ do you want to spend????
My blue 202 runs mid 13s down the quater, and theres another guy on here who has put his 202 into the 12's....
Les
_willo_
Posted 09 July 2007 - 05:18 PM
that is the obvious way but if you dont want to take ya manifolds off just post pic and those of us who know will tell youHey Danny, to tell the difference between a 9 and a 12 port head simply look at the ports, you will see 6 exhaust ports on both heads but on a red motor there are only 3 inlet ports (1 port feeds 2 cylinders) which will have a post going through the middle of the port for the head bolt. On a blue motor the inlet ports are sperate for each cylinder so you should count 6 seperate inlet ports.
Les
Posted 09 July 2007 - 05:53 PM
Look at the driver's side of the head at the front (spark plug #1 area) does it have three threaded holes pointing out towards the side of the car in the pattern of:how can i tell a 9port head from a 12 port head
o o
o
Or does is it just plain? If it has the holes, it's blue/black. If it's plain, it's red.
_dannylxss_
_willo_
Posted 10 July 2007 - 11:49 AM
_dannylxss_
Posted 10 July 2007 - 12:04 PM
Posted 10 July 2007 - 04:50 PM
Posted 10 July 2007 - 10:36 PM
Posted 10 July 2007 - 11:42 PM
A 2 barrell Holley or Stromberg will out perform a Varajet if tuned properly.
With the Varajet you will have optional economy.
Depends on your right foot.
Edited by rodomo, 10 July 2007 - 11:45 PM.
_doucmyuc_
Posted 10 July 2007 - 11:53 PM
To get going and not breaking the budget, id suggest starting out with an electronic ignition mdule conversion from a later model commodore, nice cheap bang for buck and will also help a little on the fuel economy. Most definately yt heads can be picked up under the 400 mark with needing hardly any work to be done except bolt them on. So if your pretty handy with the spanner and have got a manual, then you will certainly notice a major increase in perofrmance from this.
A ww strommy on a redline or similar manifold will help, but once you start to get serious, efi is the way to go. Ive also heard/read somewhere that the redline manifolds cause 1,2 5,6 cylinders to run lean in comparison to 3,4 due to the varied lengths of it. Most certainly its not the most ideal manifold for high high performance in the long run.
Also if your looking to hit the track a fair bit, you will find some great results from working on brake and suspension upgrades. Probably make things a lot more fun and competitive on the track.
Posted 11 July 2007 - 12:23 AM
Yep. Blue/Black manifold has superior distribution to cylinders.Ive also heard/read somewhere that the redline manifolds cause 1,2 5,6 cylinders to run lean in comparison to 3,4 due to the varied lengths of it. Most certainly its not the most ideal manifold for high high performance in the long run.
Maybe consider a Blue/Black head? Again bolt on performance.
Maybe this is still for sale? And cheap!
http://www.gmh-toran...showtopic=19117
