Brakes, not there?
#1 _hrt1and2_
Posted 25 January 2006 - 11:01 AM
Posted 25 January 2006 - 11:34 AM
Posted 25 January 2006 - 12:19 PM
Firstly i would bleed the system, it sounds like there was air in the line somewhere
#4 _Yella SLuR_
Posted 25 January 2006 - 12:27 PM
Posted 25 January 2006 - 01:48 PM
How spirited was the driving just before that? I had the EH brakes give up in normal stop start traffic not long ago...not much fun.
#6 _Yella SLuR_
Posted 25 January 2006 - 01:54 PM
#7 _hrt1and2_
Posted 25 January 2006 - 02:08 PM
am i better of gettting a new 1, or a wreckers job?
is there a good way of draining the fluid with out getting it on my paint work?
cheers.
Posted 25 January 2006 - 02:24 PM
Get your booster rebuilt
Buying one from the wreckers may be buying the same problem again
Posted 25 January 2006 - 02:32 PM
Posted 25 January 2006 - 08:03 PM
If your pedal is the right height but you have to push extra hard to pull it up, the booster or hose or check valve is faulty.
Its Hydroscopic! Hygroscopic! Why its greased lightning!
RACV MAN
Posted 25 January 2006 - 10:20 PM
#12 _CHOPPER_
Posted 25 January 2006 - 10:22 PM
Jan 1 to Dec 31.
Posted 25 January 2006 - 11:25 PM
RACV MAN
#14 _kaz from adelaide_
Posted 26 January 2006 - 01:23 AM
is that the brake proportioning valve or is that something different?I had another think in my brayn and if your "power valve" in your booster were leaking it could cause brake fade as you were driving but you would have felt a "drag" on your car.
RACV MAN
#15 _CHOPPER_
Posted 26 January 2006 - 11:04 AM
#16 _hrt1and2_
Posted 26 January 2006 - 02:12 PM
Maybe i should just take it somewhere get the work done.
#17 _CHOPPER_
Posted 26 January 2006 - 02:18 PM
Generally is the safest option.
#18 _Yella SLuR_
Posted 26 January 2006 - 04:43 PM
Thought I could smell something burning.I had another think in my brayn .....
Posted 26 January 2006 - 08:29 PM
RACV MAN
#20 _hrt1and2_
Posted 26 January 2006 - 11:06 PM
Just out of curiosity how far is the pedal ment to travel under normal conditions, mine only traves 1-2 inches from released, too full stroke, is this like most?
#21
Posted 27 January 2006 - 11:06 AM
They are not date coded unless reconditioned and they bothered to put a sticker on it with a date
Get your car diagnosed before you spend any money
Could be buying something you don't need
#22
Posted 27 January 2006 - 10:32 PM
Pushrod clearance!
You must have pushrod clearance between the pedal and booster AND the booster and master cylinder. Otherwise brake drag and fade can result.
RACV MAN
Edited by rodomo, 27 January 2006 - 10:33 PM.
#23
Posted 28 January 2006 - 09:15 AM
#24 _hrt1and2_
Posted 28 January 2006 - 01:00 PM
thanks people.
#25 _hrt1and2_
Posted 28 January 2006 - 01:30 PM
Any one recommend a good brake specilalist mechanic in Adelaide?
