How much HP can M20 handle
_gtrtorana_
Posted 27 July 2007 - 10:19 PM
Posted 27 July 2007 - 11:04 PM
_CraigA_
Posted 28 July 2007 - 09:43 AM
The clutch is my biggest drama, using ceramic but still get some shuddery slip under full power changes.
Cheers,
Craig.
Edited by CraigA, 28 July 2007 - 09:46 AM.
_70rey_
Posted 29 July 2007 - 06:34 PM
i got mine rebuilt with mazda sir clips and what not. and im expecting a heap of horses from my 6.
_gtrtorana_
Posted 30 July 2007 - 07:56 AM
_Drag lc_
Posted 05 August 2007 - 10:36 AM
Thanks Hayden
Posted 05 August 2007 - 11:33 AM
If you can stop yourself from thrashing it in the lower gears, it will give good service providing its a good box to begin with.
Remember they were behind 308's as well.
_gtrtorana_
Posted 05 August 2007 - 07:11 PM
_waratah_
Posted 29 July 2008 - 11:37 AM
We've blown 2 m20's behind a 308 now.The weak spot in the Aussies is the rear cluster needle rollers and hardening wearing through on first gear on the cluster after the needle rollers have collapsed. This runs the gears slightly out of mesh and the hardening suffers.
Pulled the second one down yesterday after removing from car.
We stripped 3rd gear on both.
We only use 2nd for take off, no use of first at all, on track its 3rd and 4th only.
after losing third in the First we parked ASAP and only the damage was left at 3rd gear stripped.
The 2nd one we done a few more laps and disintegrated the front bearing losing all gears but top.
Had m20's behind quick 253's and they handle the same racing conditions
Posted 29 July 2008 - 11:49 AM
When I rebuilt my g-box, I found a fare amount of wear on the lay shaft/needle rollers. I rebuilt box 10,000 kms ago so by the replys recieved, as long as I remember to take it easy when changing in the lower gears, I should be right. By the sounds of things, I will have more trouble with my course spline diff and axles than the box. Thanks for info. Next question may need another topic, how much to change from banjo rear end to VN commodore rear end with BW78 diff?
The VN commodore rear end "should" be a relatively straight forward job. The only major drama i can see with it, is the setting of the new brackets once the old ones have been taken off. If they are not set 100% (or close enough) to square the rear will be out of line, and could cause handling trouble, not to mention extra stress on the chassis.
I plan to give it a go in the next 12 months with a disc brake LSD from a VN calais. Hopefully you do it first so i can see what could go wrong! hahah!
Posted 29 July 2008 - 12:38 PM
Posted 03 August 2008 - 08:54 PM
It also busted the front bearing of the M20 twice which I cant say we resolved because he sold the car before it happened again.
_Brad1979UC_
Posted 04 August 2008 - 01:34 AM
Posted 04 August 2008 - 02:38 PM
just make sure that you use a really good quality oil in the box
Redline Blue would be about the best
peter
_The Stig_
Posted 04 August 2008 - 06:33 PM
I've busted a couple of M20's behind 308's. Never had a problem with a 6. It's torque that breaks things, not horsepower. Both the ones I've broken, and most broken ones I've seen have stripped the teeth off the input shaft and cluster drive gears. Probably all stems back from worn layshaft and/or bearings tho...Mine has about 260-270 seems fine
peter
_ljharbsy_
Posted 07 August 2008 - 10:28 PM
Interesting reading, I build these buggers all the time, the best you can do with them is machine some more oil clearance under the 1st gear area only in the middle to allow more oil flow they tend to glue 1st gear to the mainshaft, get the second gear circlip machined to take the same size circlip as the one used on the input shaf bearing, as for the cluster wear get it resleeved, if you don't this will just add extra metal to the box, also use sealed bearings, this helps with wear. You can also machine the selector side plate so 2nd gear hits right in, other than that if you want to use a GM 4 speed go to a Muncie box, they are aluminium cases and much lighter than the saginaw and a bit stronger.
Steve
Posted 09 August 2008 - 07:54 AM
You can get the b/w diffs & gears cheaply.make sure it's a 28 spline diff...getting the lsd centres is not so cheap though.I think the b/w diff cost me $7-$800 when I got it done for my lc.
Posted 09 August 2008 - 09:44 AM
_gtrtorana_
Posted 09 August 2008 - 11:43 AM
Thanks for your productive input to my questionYa know paris hilton, well thats how bad M20's suck IMO
To everyone else, interesting reading, Thanks.
_Chriskoss-79uc_
Posted 09 August 2008 - 09:45 PM
Sometimes I go out when im pissed off and give the old M20 a thrashing.. double clutching and fourth to 1st gear in a second. Who gives a shit. Torana's are built to last!
#21
Posted 10 August 2008 - 12:13 AM
I thought she sucked pretty good...but thats all she did well.
Mate it will handle anything!
Now do it in a kingswood, same drive train....
#22
Posted 10 August 2008 - 02:08 PM
Yeah, they both suck.
