Engine coolant
19 replies to this topic
#1 slr5640
slr5640
    XA9X
  • 798 posts
  • Name:Brian
Posted 14 August 2007 - 09:19 PM
I've read the sticky on coolant etc. and was wondering which type /brand people here would recommend/not recommend for their motors. It seems important to have an additive which is corrosion inhibiting as well as lubricate the water pump.
So many choices at Auto Pro don't know which one to get????
#2 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 14 August 2007 - 09:27 PM
I use Nulon myself
#3 TerrA LX
Posted 14 August 2007 - 09:59 PM
Lubricate the water pump LOL what a gimmick, the pump runs a sealed bearing.
#4 rodomo
  • 18,045 posts
Posted 15 August 2007 - 12:26 AM
I use Castrol corrosion inhibitor. Comes in small cans and is a concentrate. I use 2 cans on my cars. I dont use antifreeze/boil as I don't go to the snow and my cooling systems work.
With the lubrication thing, all it lubricates is the seal and most water pump seals these days are carbon/ceramic and self lubricate.
#5 orangeLJ
Posted 15 August 2007 - 07:48 AM
i use good ol' H2O in the torana.
#6 _MAWLER_
_MAWLER_
Posted 15 August 2007 - 09:27 AM
Nulon, mixed at 50% for me.
#7 fatslr
fatslr
  • 1,247 posts
  • Name:Garth
Posted 15 August 2007 - 11:02 AM
Toyota long :spoton: life coolant is the ducks guts pretty expensive but from experience my 80 series landcruiser at 250000 ks changed coolant and bottom neck of water pump looked like new you wont have to worry about corroded timeing covers or inlet manifolds with this coolant
#8 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 15 August 2007 - 05:34 PM
Genuine Holden Concentrate, Bout $40 a 5 lt bottle, I run a buit over 50% mix in the monaro and it's been great
#9 ls2lxhatch
  • 5,334 posts
Posted 15 August 2007 - 05:48 PM
Check which standards the coolant satisfies. Last time I looked there were quite a few brands that did not meet the Holden's specifications for the VZ. Nulon meets or exceeds the Holden specifications. I would not run pure water in anything.
Nulon
http://www.nulon.com...hp?productId=ll
http://www.nulon.com...p?productId=rll
#10 _1BADSS_
_1BADSS_
Posted 15 August 2007 - 06:27 PM
I also use this inhiditor and it works!!!
#11 TerrA LX
Posted 15 August 2007 - 06:45 PM
Nulon or Castrol inhibitor for me. I do not use antifreeze.
#12 _nunganunga_
_nunganunga_
Posted 15 August 2007 - 06:48 PM
I was looking at a late model echo the other day and found the service interval for changing coolant at well over 100 000 ks (cant remember exactly). I think it is called super long life and is fluro pink in colour. It is supposed to be the new improved and a step up from the already excellent(as fatslr knows)red long life.
#13 orangeLJ
Posted 15 August 2007 - 07:12 PM
whats wrong with running water? old man did it all those moons ago and never had any dramas, so whats changed these days??
#14 TerrA LX
Posted 15 August 2007 - 07:42 PM
^ show me some pictures of the thermostat housing he was using.
#15 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 15 August 2007 - 08:05 PM
Aren't there different types depending on whether the majority of the block/head internals being cooled are aluminium or cast iron?
#16 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 16 August 2007 - 06:35 PM
THe holden coolant i use is alloy compatible ( used in the alloy LS1s) and also good for iron blocks.
I ran it for 12 months on the old motor ( Straight! No dilution which probably wasnt right) but there was N O corrosion whatsoever.
#17 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 16 August 2007 - 07:24 PM
Chris...if its straight water and nothing else..it wont stay straight water for long...it turns a lovely rusty colour...when that boils it creates a lovely mud that hides at the back of the block...when bits of the "hot rocks" break off they lodge in the tubes of your radiator.
I am currently cursing one of my engines previous owners...and its not the one before me...but all before Tuff will earn a nasty memo!
#18 slr5640
slr5640
    XA9X
  • 798 posts
  • Name:Brian
Posted 16 August 2007 - 10:37 PM
Lots of great suggestions here. Also received other info on the subject Thanks
Not quite as confused now. Will go for an anti freeze/ anti boil inhibitor combo. Heaps of advantages over just an inhibitor.
#19 WhiteA9XS
WhiteA9XS
  • 1,646 posts
  • Name:Shaun
  • Car:LJ LX
Posted 16 August 2007 - 11:16 PM
good old castrol for me too ... its proven , i,ve tried others to find sludge build ups after pulling a motor down .... castrol no problems ..
#20 orangeLJ
Posted 17 August 2007 - 08:34 AM
i see your point but my radiator water gets dropped atleast once every couple months. and with all the continual things we do to the car, its cheaper and easier on the lawn to just use water.
i run coolant in all of our late model cars, just dont bother with the torry.
