MILD:
Provides good idle quality with good fuel economy & throttle response between 1500 rpm - 4000 rpm & goes to a
maximum of around 4700 RPM
Cam spec sheet is included with the cam
Brand
Genuine Speed Pro - Made In USA
Specs
Adv duration - int 260 deg ex 270
Duration @ .050" - int 194 deg ex 202 deg
Valve lift - int .390" ex .410"
Lobe separation - 110 deg
and 'HOT':
It has a good idle with lope & provides good mid - upper RPM power & torque between 1800 rpm - 4500 rpm & goes to a
maximum of around 5200 RPM
Specs
Adv duration - int 282 deg ex 282
Duration @ .050" - int 208 deg ex 208 deg
Valve lift - int .422" ex .422"
any thoughts? i'm looking to do a bit of work to my motor and was just wondering if these would be a viable option. also would the 'powerboss' lifters that they sell be suitable and any good?
chris
Edited by bon_scott, 31 August 2007 - 12:45 AM.
