im looking at a 'GTR' head for sale... dunno what it really is tho.
has numbers 2811930. also another stamping on it is F2 and i cant make out the other bit as they arent clear pics.
anyone have any info?
GTR Head
_SLR_6_
, Aug 31 2007 07:29 PM
6 replies to this topic
_SLR_6_
Posted 31 August 2007 - 07:29 PM
Posted 31 August 2007 - 07:37 PM
HI
I think you will find that there is no difference between an LJ GTR head and any other LJ 202 head. The number you have quoted is correct for both.
Bazza
Bazza
_threeblindmice_
Posted 02 September 2007 - 09:44 AM
Don't the high compression and low compression heads have different numbers one ending in 29. And did the GTR have a high compression head??
Posted 02 September 2007 - 10:28 AM
Hi threeblindmice,the 2811930 is the high compresson head,cheers.
_XUI202_
Posted 10 September 2007 - 09:44 PM
if 2811930 is a gtr hi comp head why do they have a l at the back of the head?
were a 2811929 has a h at the back of the head???
thanks robert
_debbiedavid_
Posted 10 September 2007 - 09:54 PM
Back of the head has the cast date
Cheers Dave
Cheers Dave
Posted 11 September 2007 - 04:31 PM
Hi Guys.
This high-comp & low-comp thing pops up all the time, it goes like this.
The 2811930 head is the open chamber head that is fitted to the normal (high-comp) 202. A low-comp 202 also uses the same head, but uses pistons with a larger dish to achieve the lower compression.
A normal (high-comp) 173 uses the 2811929 closed chamber head, but the low-comp 173 uses the 2811930 (open chambered) head. So the H & L castings only have any real meaning when fitted to the smaller (173) engine. The L casting is the open chambered head & results in the lower comp ratio, the H gives a high comp ratio.
Dr Terry.
Dr Terry.
