side exhausts
_202_lx_
Posted 15 September 2007 - 07:33 PM
thanks
_trna76hb_
Posted 16 September 2007 - 06:39 AM
So no it is not legal.
Ian
_willo_
Posted 16 September 2007 - 08:07 AM
_kangur_
Posted 16 September 2007 - 08:29 AM
_Yella SLuR_
Posted 16 September 2007 - 03:46 PM
The explanation is not correct. 100mm(???) in a vertical line behind the rear most opening window (not doors or hatches). That's the Australian Design Rules. CAMS adopts the same. As for road registered cars, I believe that any exhaust exiting the side of the car must also point downwards, so you can't fit Group C type exhausts to a road registered car. Also a self tapper through the window winding handle disabling a window makes it non-opening, and again, you'll see that on the race cars as well.The exhaust has to exit behind the last opening thing that goes into the car, windows, doors & hatches etc.
Ian
Hope that helps.
Edited by Yella SLuR, 16 September 2007 - 03:49 PM.
_LXBren_
Posted 17 September 2007 - 10:30 AM
everything he said cept i think it's 300mm.The explanation is not correct. 100mm(???) in a vertical line behind the rear most opening window (not doors or hatches). That's the Australian Design Rules. CAMS adopts the same. As for road registered cars, I believe that any exhaust exiting the side of the car must also point downwards, so you can't fit Group C type exhausts to a road registered car. Also a self tapper through the window winding handle disabling a window makes it non-opening, and again, you'll see that on the race cars as well.
Hope that helps.
(Just went through this with the side pipes on my lx - took them off)
Posted 18 September 2007 - 06:46 PM
I could remove the core of the Megaphone and just put the end cap back on and just enjoy some sweet notes as you wind the 308 to 7000rpm through the winding mountain roads.
