Celica 5 spd conversion
9 replies to this topic
#1 _MrNatural_
_MrNatural_
Posted 12 October 2007 - 10:28 AM
Hey guys just put a 5 speed celica box into my LJ torana.THe speedo is out by about 10 mph.Just wondering how you can fix this?
I have 3.08 banjo in the back
#2 _timbotorrie_
_timbotorrie_
Posted 12 October 2007 - 07:46 PM
you will have to change the gear in the speedo transducer, its mounted in the extension housing, they are different colours to reflect the number of teeth on the gear i think.
it depends if you are reading too fast or too slow as to which gear you will need
#3 _73LJWhiteSL_
_73LJWhiteSL_
Posted 14 October 2007 - 04:08 PM
I didn't think you could change the speedo driven gear with a Celica 5 speed box. I thought that was just the Aussie boxes.
I have a 3.36 banjo in mine and the speedo reads a touch fast but nothing major so i just live with it.
Other option is to get a corection 'gearbox' made up that goes on the end of the speedo cable and goes into the box to fix the problem, but they start at around $300.
Steve
#4 _Morry_
_Morry_
Posted 14 October 2007 - 06:28 PM
im doing the same conversion, will it always be out by a little bit or is there a way i can make sure its right?
#5 TerrA LX
Posted 14 October 2007 - 06:47 PM
It will be right if you use the same tyre diameter and final drive ratio as the toyota from where it came.
#6 limo
limo
  • 2,673 posts
Posted 15 October 2007 - 07:32 AM
the lowest diff ratio in toyota I found was 3.7 (most are 4+) that is why the 3.36 diff gives close reading,
with my conversion the LJ had 2.78 diff, I used one of those miles to kilometre conversion stickers that you get from Rares but used a 200kph on a 100mph speedo and it is only out by about 1%, tested it against speed camera reading
the guy was sitting down the street from depot and asked him to check read out when I went past ( under limit of course)
Edited by limo, 15 October 2007 - 07:33 AM.
#7 _LXBren_
_LXBren_
Posted 24 October 2007 - 07:12 PM
can I ask you what the conversion $et u back?
Looking for something too but not sure yet
#8 limo
limo
  • 2,673 posts
Posted 25 October 2007 - 09:28 AM
I was lucky under $500
gearbox $250 (complete out of LX but hydraulic clutch, I wanted cable)
commodore bellhousing $20, my son in law welded lugs on to fit toyota box
" " cable $10 at wreckers
speedo cable about $100 I think from rares
toyota clutch plate $48
spiggot bush $14
tailshalft shorten Free, my son in law again
speedo sticker $25
#9 orangeLJ
Posted 25 October 2007 - 12:19 PM
I paid 450 bucks for a steel case box from an LX, with tailshaft and correct shifter for my LJ (by accident) clutch and pressure plate, aswell as an M20.
The only thing that cost me was having the tailshaft shortened (couple hundred)
and a few other bits and peices here and there.
all up only about 700
#10 _MrNatural_
_MrNatural_
Posted 27 October 2007 - 12:45 PM
Hey guys im still having problems with the gearbox.Speedo doesnt work at all now.Iv got new cable in,but nothing.Its quite annoying.Where can you get those converter things from?
