Hi Guys.
Yes, that is correct. In the VN series there was a rare 'delete power steer' option & they simply used a VL manual rack.
VB to VK manual racks are different & will not fit.
Also this doesn't apply to p/st racks. A VL p/st rack will not fit a VN, but a VN rack will fit a VL.
Dr Terry.
Thanks for that..... Here is one for you I've been offered a Manual rack out of a
VK V8, I know you said they are different and i belive you too...... But this guy
reckons that VK V8 and VL V8 share the same crossmembers. This sounds like
something Holden would do. But from memory with the older Commodores if you
swaped the racks didn't you have to change the columb over aswell......
(Don't get old, it gets hard to remember stuff!!)
And Rodomo,
Thanks for that link, was interesting reading.... Definately food for thought. One question though.
Not knowing a hell of a lot abot power steering, this may or may not be a silly question, but here goes anyway.
Why pull the rack appart and modify it and remove the bits and pieces the way you described? Why not leave it all together and block off the inlet and outlet pipes? What advantage is there in modifing it like that, is there less friction thus making it a bit lighter???
Cheers Rally
