I already have Disc's on the front but i want disc rears now.....do i use HQ discs?? do i have to change Diff??
Edited by gooley, 20 October 2007 - 05:52 PM.
Posted 20 October 2007 - 05:50 PM
Posted 20 October 2007 - 06:12 PM
Posted 20 October 2007 - 06:17 PM
Posted 20 October 2007 - 06:36 PM
Posted 20 October 2007 - 06:59 PM
Edited by LX8VD69, 20 October 2007 - 06:59 PM.
Posted 20 October 2007 - 07:29 PM
HX HZ etc did come with HQ 'type' rear brakes if that makes sense, its what I run on my LX sedan but it has a 10 bolt Salisbury diff. Rim is correct when he states HQ were not disc brake.Well for a rough start, HQ's didn't come with disc rears...
Shortened VN/VL/Skyline diff seems to work alright.
Tim
Edited by Herne, 20 October 2007 - 07:32 PM.
Posted 20 October 2007 - 10:14 PM
Are you talking about bolting the VN Disc rotor to the Torana axle? How did you mount the calipers?ive used VN commodore, ive had the discs redrilled to torana stud pattern and they will bolt straight on. the only 3 things you will need to do is: youll need to get a 1/4 inch spacer made that goes between the axle mounting plate on the axle and the axle seal other wise the seal will sit out too far and all your diff oil will leak out (i used rear bearing cups that i had machined down to 1/4 inch thick), youll need to pull the little brass proportioning valve out of your master cylinder, other wise after the first couple of time of hitting the brakes they will lock on and the last thing youll need to do is get a hand brake cable made, i dont know where the hand brake set up goes on the bottom of an LC/LJ so i cant make any recomondations there. its not all that hard but a little involved
cheers adam
Posted 21 October 2007 - 12:50 AM
i used the whole commodore set up so i just used the caliper mounts that come with itAre you talking about bolting the VN Disc rotor to the Torana axle? How did you mount the calipers?
Steve
Posted 21 October 2007 - 08:06 AM
Posted 21 October 2007 - 09:46 AM
Posted 21 October 2007 - 08:59 PM
Posted 21 October 2007 - 09:03 PM
Edited by LJ_MAN, 21 October 2007 - 09:05 PM.
Posted 22 October 2007 - 12:47 AM
Posted 22 October 2007 - 02:23 AM
Posted 22 October 2007 - 07:59 AM
Hi rodomo.Some utes (Hi-lux springs to mind) have a load sensing valve that adjusts the rear brake pressure depending on the load in the tray from the factory.
Virtually what you need but not adjustable from the cabin.
It is adjusted under the car via an adjustable rod.
Sort of a set and forget set-up.
Maybe it could be argued via an engineer to fit it?
Posted 22 October 2007 - 05:07 PM
Edited by rodomo, 22 October 2007 - 05:08 PM.
Posted 22 October 2007 - 06:52 PM
Posted 22 October 2007 - 07:07 PM
Mate, have a read of Dr Terry's post.OEM proportioning valves in the LC/LJ's dont have a brake fail switch, its just a brake light switch so i cant see any disadvantages in not having the switch.
Posted 23 October 2007 - 08:55 PM
Posted 27 October 2007 - 10:10 PM
Posted 30 October 2007 - 05:24 PM
Posted 30 October 2007 - 06:41 PM
Posted 30 October 2007 - 07:13 PM
Hi Grant.HQ-WB utes have a load sensing proportioning valve in the engine bay.
With no weight on the rear (or the rear rising during braking) more bias in dialed toward the front to prevent rear lockup.
Grant..
