Oil pump change for 202, good oil pres?
8 replies to this topic
#1 _JBird_
_JBird_
Posted 21 October 2007 - 06:47 PM
Heres a few quick ones.
My block is a 'ZL' prefix...does that mean it's a black motor block?
What's a good oil pressure to have for a mild 202?
When changing the oil pump, can the engine be left in the car? It doesn't look like much space? Can someone outline the procedure in case I mess it up.
Anyone have a good condition 'standard' oil pump they want to sell/give me?
Thanks all
James
#2 _gtrtorana_
_gtrtorana_
Posted 21 October 2007 - 07:01 PM
You will have to remove bolts from drivers side mount and jack engine up to remove pump. Make sure you prime new oil pump before fitting.
#3 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 21 October 2007 - 07:04 PM
Depends on the car as to whether you can change "in chassis"...hold your spare (when you get it) up next to it to judge clearance...you cant do it in EH's :<_<:
what pressure do you have?
simply undo the 4 bolts in the corners..the middle 2 hold the front plate on...but i tend to find it is rarely the pumps fault..its bearing clearances :blink:
I think you have a HZ engine..will have to check.
#4 _JBird_
_JBird_
Posted 21 October 2007 - 07:23 PM
My gauge is not working though it was about the 1/4 mark when it was...
Will have to get a the gauge fixed.
Oil pump shaft had about 60 thou play in it when it was put in because I couldn't afford a new one at the time of rebuild. I think oil pressure was around 30 ??
Sorry its in an LJ.
Are all oil pumps the same for red,blue,black blocks?
How do I prime an oil pump?
#5 _torana_
_torana_
Posted 21 October 2007 - 07:51 PM
i usually pack full of vasoline, but thats on a 253 / 308. ( the oil pump that is :D )
cheers julian
#6 _JBird_
_JBird_
Posted 21 October 2007 - 07:54 PM
cheers julian
lmao.
I think it's the same.
Thanks for the replies guys.
Now I'm on the hunt for a good condition standard oil pump.
#7 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 21 October 2007 - 08:10 PM
You can have one of mine..PM address :D
#8 _73LJWhiteSL_
_73LJWhiteSL_
Posted 22 October 2007 - 12:39 PM
I packed mine full of vasaline to prime it 1 1/2 months ago, and it worked fine.
Steve
Edited by 73LJWhiteSL, 22 October 2007 - 12:39 PM.
#9 gtrboyy
gtrboyy
  • 3,241 posts
Posted 22 October 2007 - 04:24 PM
I still got the one of my old 202 James.Hi volume pump though.
