5lt inj help
#51
Posted 14 November 2007 - 05:00 PM
#52 _wraith75_
Posted 14 November 2007 - 05:01 PM
#53
Posted 14 November 2007 - 05:05 PM
#54
Posted 14 November 2007 - 05:07 PM
#55 _wraith75_
Posted 14 November 2007 - 11:03 PM
and matty it will be ready to come out PROMES hahah
Edited by wraith75, 14 November 2007 - 11:04 PM.
#56 _wraith75_
Posted 16 November 2007 - 11:39 PM
so now i need to do all the work BUGGER .
#57
Posted 30 November 2007 - 04:34 PM
#58 _wraith75_
Posted 19 January 2008 - 11:28 PM
#59 _evil UC hatch_
Posted 20 January 2008 - 11:35 AM
#60 _wraith75_
Posted 20 January 2008 - 02:49 PM
yep there are some picks to come i will be starting a bild thred so every 1 will have to wait hehehe as im doing it all at once bit like a book .
There were some small things that were a prob like the whole thing but thats car's .
But a BIG thanks to rodomo agen u the man......
#61
Posted 20 January 2008 - 03:32 PM
#62 _wraith75_
Posted 20 January 2008 - 04:38 PM
found it BOSCH MOTOR SPORT 044 , REPLACEMENT EFI FUEL PUMP (#140175558548)ebay is were it was .
Edited by wraith75, 20 January 2008 - 04:43 PM.
#63
Posted 20 January 2008 - 04:46 PM
#64 _wraith75_
Posted 20 January 2008 - 04:51 PM
#65
Posted 20 January 2008 - 05:36 PM
I thought the VL had the low pressure pump intank, feeding to a high pressure external pump. Or was that just the 6?
The vn has just external high pressure pump?
I have all of the above. Just cant decide on which to use.
Cheers, Col.
#66
Posted 20 January 2008 - 05:57 PM
haha opps! jump on msn when u are ready and ill upload the pics for yaYES the one that leeked hahaha it did we dident tigten all the brase nuts OPS hahaha ill go get 1 then we can start a bild histery .
#67
Posted 26 January 2008 - 09:27 PM
This wiring kit did the job but the instructions were a bit vague.Ok got the wiring sorted i just got a pack from v6� conversion specialist in nsw it cost $400.00 wich was cheeper than crs by $350.00 go figger .
so now i need to do all the work BUGGER� .
There were wires and a couple of plugs hanging off the loom with no reference in the instructions or diagrams.
Fortunately, Petroject had given us a wiring diagram when they by-passed the VATS.
Also the ign. supply to the computer and another wire (starter solenoid from memory) had dodgey spade terminals to join them after you poke the loom through the fire wall.
After we got it running, we then went about tidying the loom up and fitting convoluted tubing over it all. Guess what? The dodgey spade connections came undone while this was happening.
Took about another hour to find the fault, strip the loom and solder the buggers
A couple of quotes from the day:
Wraith: "Lets just plug the computer in and see what happens!"
(This after a bit of head scratching over the loom and the extra plugs)
Result: The bloody thing ran!
Then after it was running but wouldn't stop when the key was turned off:
RoDoMo: Just cut that pink wire and see what happens!
Result: The car now turns off with the key!
Edited by rodomo, 26 January 2008 - 09:31 PM.
