indicator switch
10 replies to this topic
#1 _wildsix_
_wildsix_
Posted 18 November 2007 - 01:55 PM
My front drivers side indicator lamp isnt working, theres no power going to it.
checked the flasher its working, bulb ok, it appears the actual switch in the steering column is at fault, also the dash indicator lamp for this side doesnt light up. I think the signal wire splits and goes to the front lamp and indicator dash lamp, thus reinforcing that the fault is in the column.
any ideas, fixes
#2 rodomo
  • 18,058 posts
Posted 18 November 2007 - 02:50 PM
There is a downloadable wiring diagram for LJ here.
http://www.gmh-toran...?showtopic=3626
May be the same as LC for indicators?
Looks like either the switch or the 1st connector from the switch could be at fault.
#3 _nunganunga_
_nunganunga_
Posted 18 November 2007 - 04:33 PM
Pull the switch apart and check to see if any of the three contacts/brass strips are broken.
#4 _Flamenco_
_Flamenco_
Posted 18 November 2007 - 04:35 PM
LC's and LJ's have different indicator mechanisms unfortunately... LC are the same as HT HK HG and LJ are like HQ, HJ etc :)
#5 rodomo
  • 18,058 posts
Posted 18 November 2007 - 05:21 PM
Is the wiring diagram the same though?
#6 _Flamenco_
_Flamenco_
Posted 18 November 2007 - 07:40 PM
Very close but some differences would be the lack of side repeaters in the back of LJ's etc
#7 _73LJWhiteSL_
_73LJWhiteSL_
Posted 19 November 2007 - 08:01 AM
I would be checking the earth first. I had a problem where my drivers side kept loosing the earth connection, despite the fact a bolt goes straight into the nose cone from the indicator. In the end i ran a wire from the headlight earth (radiator bolt) down to the back of the bolt on the indicator and no problems since. Didn't have the problem on the passenger side.
Maybe its not the earth but worth checking.
Steve
#8 gooley
gooley
  • 529 posts
  • Name:Jason
  • Car:Holden Torana LC 1970 Coupe
Posted 04 December 2007 - 06:56 PM
remember LC have rear side indicators we're LJ's dont but you are looking at front so this might not matter
#9 _wildsix_
_wildsix_
Posted 29 February 2008 - 09:13 PM
I traced the fault back to the actual switch contacts, can you get replacement ones of these?
#10 _nunganunga_
_nunganunga_
Posted 02 March 2008 - 10:47 AM
Good luck, The last one i bought came from ebay.
#11 Dangerous
Dangerous
  • 948 posts
Posted 02 March 2008 - 08:55 PM
HK/T/G electric in the steering cloumn are the same as LC, if that helps at all. As mentioned, the front indicators earth via the mounting stud - and they always corrode.
