Headlight dipper switch
_slr3300_
Posted 08 December 2007 - 08:24 PM
On my lx the hi beams aren't working- traced it back to the dipper switch. The 2 wires have come off the 3 little terminals on the switch. Is there supposed to be a 3rd wire? Terminals are numbered 123. From memory- i think there was a white and green wire- anyone know which one goes where?
Posted 08 December 2007 - 11:13 PM
Checked my new spare switch, unfortunately it has C - NO - NC not 123.
So for the new switch its C - NO, its easy to check with a test light.
1 - 2 or 1 - 3 their should be no light until you press the button.
Someone else with a wire diagram should be able to confirm this, or i can tomorrow.
Posted 09 December 2007 - 12:15 AM
It also says the wire to the relay is the white wire.
I assume the green goes to earth as per the diagram but it doesn't state a colour.
Without more info I would assume that the relay is a "changeover" relay that contacts one beam when powered up and the other when at rest.
Page 1 of this thread gives a bit more of a clue:
http://www.gmh-toran...topic=3275&st=0
Posted 10 December 2007 - 02:44 PM
As Rodomo said, switches the earth (11) to the headlight relay (15) on the white wire.Without looking at a wire diagram (It's not at home at the moment), should be across the normally open pair.
_slr3300_
Posted 11 December 2007 - 05:49 PM
