th700 vs th350
_uglybob_
Posted 05 February 2006 - 03:23 PM
some people tell me yeh they the same just one has an OD others say the 700 is just crap. so whats everyone ones experience / opinion with them?
Posted 05 February 2006 - 07:11 PM
_Torana482HP_
Posted 05 February 2006 - 07:33 PM
_uglybob_
Posted 05 February 2006 - 08:55 PM
_Torana482HP_
Posted 05 February 2006 - 09:31 PM
_uglybob_
Posted 05 February 2006 - 09:52 PM
_MYLJ_
Posted 05 February 2006 - 09:58 PM
Posted 07 February 2006 - 07:47 AM
_Bedford_
Posted 08 February 2006 - 03:05 PM
Posted 09 February 2006 - 05:49 PM
4L60-E was VR-onwards electronic version.
The early ones still run an electronic speed sensor, but you dont need this for an old carby engine.
Either version there all weak. In short to get a TH350 and a T700 to the same strength a 350 would cost $2,000 and a 700 would be $4000. Or you can put a standard T400 in and it will be stronger then both with factory replacement parts.
If you have the room to fit it you cant go past a TH400, unless you want a 2 speed.
_salaszar_
Posted 10 February 2006 - 07:10 AM
Up to 500HP and at $3000 you need it blue printed and parts fitted that are not off-the self (There is a company in Australia that does this).
Up to 580HP you need some special upgrade parts which I have not heard of in the Australia so you will need to go to the USA.
Higher than 580HP,,,no way (yet).
TH400,, very tough,,or its big brother 4L80e for twice the price.
_TORANR AMORE_
Posted 10 February 2006 - 01:30 PM
I asked a similar question about the Turbo Hydramatics some time ago and found this information over the net very useful:
The three links below are for specifications, advantages and disadvantages as well as background for each of the TH400, TH350 and TH700
http://www.novak-ada...ledge/th400.htm
http://www.novak-ada...ledge/th350.htm
http://www.novak-ada...dge/th700r4.htm
The TH400 can take the most horsepower, but is not as 'snappy' as the other two and can also be a drain on your system.
The TH350 and TH700 can both be worked up for extra strength. I wouldn't consider the TH700 as crap, It has more advantages over the TH350 for street use but personally I would not use it for a race car, although it would be perfectly fine for a race car (it has a good ratio on the first gear and so on)
All 3 Turbo hydromatics will fit into an LX behind a 253/308 with the turbo bolt pattern.
I have a TH400 in my sedan, it's currently a drain on the whole system (it uses btw 12 to 17% of the engines power just to operate) and I want it out! It would be fine behind a 450HP worked 350 Chev, but not for my stock 308. If I were offered to swap with a TH700 I would take it, although I would probably have to change my tailshaft.
TH400's are also cheaper for parts and kits although your automatic mechanic wont admit to it.
You have to weigh up the pro's and con's and decide really what you want the box for.
Edited by TORANR AMORE, 10 February 2006 - 01:33 PM.
_salaszar_
Posted 10 February 2006 - 04:40 PM
Posted 10 February 2006 - 07:53 PM
btw th700 has shit ratios, for street and racing. there good on a stock car were economy is a priority as you can run 3.08 in the rear and still have a good first gear, but once your in 2nd those boxes are shit.
Its a 3.06:1 1st then drops to 1.8:1 in 2nd, big drop, once in 2nd if you put your foot down there is no response its a waiting game for it to wind out.
_TORANASS_
Posted 10 February 2006 - 11:34 PM
Ultimatly T350 would be your bet, can take heaps of HP built correctly.. $4000 for an auto is ALOT of money, for that sort of money you would want it Full manaul valve body, Transbrake, Top shelf converta at least..
Depends on what you need it to do.. Ultimatly a 2 spd Power Glyde is the toughest and best for a race car.. Then again it depends what your gone use it for...
John
Posted 11 February 2006 - 05:38 PM
_uglybob_
Posted 19 February 2006 - 01:36 PM
cheers again
ben
