Inlet and Exhuast manifold sealers
_73LJWhiteSL_
Posted 27 December 2007 - 10:26 PM
the 173 has a bad exhaust leak, and i was wonderin, what stuff do you guys use?
Obviously you have a gasket, but whats your prefered sealer?
Steve
Posted 27 December 2007 - 10:34 PM
Posted 27 December 2007 - 10:50 PM
_73LJWhiteSL_
Posted 27 December 2007 - 11:01 PM
Since i've learned about oil pump gaskets ( just the gasket and a bit of loctite #3 does the trick perfect, I've gained preassure back to where i was before i did the bearings and rear main seal and it hasn't leaked a drop) I may as well learn abou the exhuast and inlet gaskets.
Steve
Posted 27 December 2007 - 11:17 PM
Posted 27 December 2007 - 11:22 PM
Yes metal are the go.The metal style one.
Since i've learned about oil pump gaskets ( just the gasket and a bit of loctite #3 does the trick perfect, I've gained preassure back to where i was before i did the bearings and rear main seal and it hasn't leaked a drop) I may as well learn abou the exhuast and inlet gaskets.![]()
Steve
There are some that are like a perforated metal/asbestos type of thing, but the best ones have like a fire ring that surrounds the ports.
_73LJWhiteSL_
Posted 27 December 2007 - 11:28 PM
The red loctite stuff isn't high enough temp. You have to use the Copper stuff. Tried that... sealed it for a while, cause it was done in Sep.Sylastic? I dunno the red stuff. Clean both surfaces then coat both sides of the gasket liberally, bolt it up and you only do it kinda finger-tight, wait a little while and then torque the bolts up properly. Has worked fine on all the motors I've done it to, never done it to a Holden 6 though...
Rodomo, this one is metal with lots of 'holes' or 'pits' in it. One of them. Where would i get the ones with 'fire rings'?
Steve
Posted 27 December 2007 - 11:51 PM
I looked out in the shed (I thought I had one) and they were both the perforated as you described.
Maybe they are genuine?
Shop around.
Posted 28 December 2007 - 06:50 AM
He has used it for years and never had a problem.
Anybody else heard of this ?
Posted 28 December 2007 - 05:14 PM
I checked at Burson's and Repco today and they both only have the perforated ones.I dunno.
Shop around.
The bloke at Repco knew what I was talking about and mentioned the "asbestos" scare thing and hasn't seen one for some time.
He said best to look for "old stock".
Posted 28 December 2007 - 09:57 PM
Edited by Heath, 28 December 2007 - 09:59 PM.
Posted 28 December 2007 - 10:16 PM
Posted 28 December 2007 - 11:03 PM
There is nothing wrong with the perforated ones if all is good, but it seems like Steve is having "issues" and the other type will seal better for longer.What's wrong with the perforated ones? I've bought one that wasn't perforated from box hill auto spares but I can't remember it having any kind of firing ring...
Posted 29 December 2007 - 08:49 AM
_73LJWhiteSL_
Posted 29 December 2007 - 12:51 PM
Steve
_coupe202_
Posted 29 December 2007 - 02:20 PM
Posted 30 December 2007 - 10:18 PM
whats this thing about oil pumps that you learntThe metal style one.
Steve
