hi i blew a fuse the other day i replaced the fuse and now no brake lights ive got high beams low beams front and bak indicators no dash light or interior light or number plate light ive changed fuses and globes still nothing
no brake lights
_bronjak_
, Dec 29 2007 10:18 PM
8 replies to this topic
_bronjak_
Posted 29 December 2007 - 10:18 PM
_Flamenco_
Posted 29 December 2007 - 11:58 PM
LC / LX, which torana? lol!
High beam switch is still ok?
Posted 30 December 2007 - 09:06 AM
Do the front and rear park lights work?
LX right?
LX right?
_xu1l34a9x_
Posted 30 December 2007 - 09:25 AM
what model torana we talking about
_bronjak_
Posted 30 December 2007 - 10:32 AM
sorry fellas lx torana no parkers at all
Posted 30 December 2007 - 11:49 AM
Maybe the fuses again?
Or the power wire may have come off the back of the fuse panel?
Both the parkers and brake light are direct power from the battery.
Maybe the fusible link at the starter too?
_LSmallmon_
Posted 30 December 2007 - 03:46 PM
Mine had the same problem last week and all i did was put a green 30 amp one in it. They work now
_The Baron_
Posted 30 December 2007 - 10:37 PM
Is that smoke I smell??
Be careful, the wiring guage is generally light for the fuse rating used from the factory.
Doubling the fuse rating from 15A to 30A allows the temperature to rise beyond that of the insulation rating and it melts.
From there it just gets worse.
Find the fault don't mask it!!
Back to the question at hand:-
Have you noticed where the wiring loom runs in the boot??
Yep, right under all that heavy crap you chuck in there.
Good luck
Good luck
Posted 02 January 2008 - 02:16 PM
Same fuse for "Stop (brake) - Tail - Dome - Horn". Replace the fuse again with the same rating, and actuate one of the above at a time, and see which one blows the fuse.
It will usually be a dodgy trailer plug wiring, or the remains of the repair job when the dodgy trailer plug was removed, or it will be the $5 install job on the $350 CD radio which has squashed the night illumination wire against the side of the metal dash or the CD unit. Could also be a rusted out number plate light housing.
Good luck.
Good luck.
