Cleaning spray guns?
Posted 06 January 2008 - 10:33 AM
Whats the deal with cleaning spray guns? Is it just a matter of running some clean thinners through them or do you have to pull them apart?
I've got a couple of new guns and I dont want to stuff them up.
_Yella SLuR_
Posted 06 January 2008 - 11:22 AM
This is the way I do it:-
Poor excess from gun into mixing bowl. Disassembe water trap and leave to dry out. Poor excess paint back into can from mixing bowl (don't mix paint in your gun). Poor thinners into paint bowl. Swirl, and spray through the gun. Empty contents into paint mixing bowl once you've put excess paint back into can. Get tooth brush and rag, and sit and disassble and clean of any paint you can see/find, including air hoses.
Ooops, as I found out yesterday, for paint to flow out, air needs to flow in, so be mindful of cleaning your air releif valve/opening assembly as well to maintain good paint flow.
Edited by Yella SLuR, 06 January 2008 - 11:26 AM.
_Yella SLuR_
Posted 06 January 2008 - 11:28 AM
If it assists I can scan and put up my gun manual, which includes maintenance items. Alternatively, most manufacturer's place their manuals on the net, so you could just get onto an airgun manufacturer and download your own.
Posted 06 January 2008 - 11:51 AM
Tip out left over paint (I spray 2k, cant reuse it.) into waste drum, quarter fill pot with thinners, put gun back on, swirl it around for a bit, then take gun back off and tip thinners out. Quarter fill with thinners again, put gun back on, swirl it around a bit, then tip thinners out again. Now Quarter fill the pot with thinners once more, put gun back on, plug it in and spray till the thinners coming out is clear. Now undo the air cap 1 half a turn, hold your finger over the front of it and pull the trigger. You will hear the thinners in the pot bubbling. This is called a reverse blow back. Tighten the air cap up again and then spray clean thinners through the whole thing again and if necessary use the thinners in the pot with a tooth brush to clean the air cap.
Thats it, long winded but takes under a minute.
At home its a different story, my main spray gun atm retails for around $660. So i follow more like pats method and make sure its spotless. Considering all i ever really spray is 2k its a lot easier to make sure every things nice and clean before the paint dries...
_Yella SLuR_
Posted 06 January 2008 - 11:57 AM
With the two pack, something I've always wondered, how long do you have to clean the gun? Not that I'll probably ever use two pack, just something that I've always wondered about.
I have flow coat coming up for my canoe soon, so will need to know some of the intricacies of working with two pack solutions, although I think flow coat will require acetone for clean up.
Posted 06 January 2008 - 05:39 PM
Sooner the better, where the paint meets the needle inside the gun is a common place for build up and if you just do the rince job on your gun it will eventually catch up with you and usually when you are half way thru painting a roof does a gun blockage show up.With the two pack, something I've always wondered, how long do you have to clean the gun? Not that I'll probably ever use two pack, just something that I've always wondered about.
I dismantle the gun (cap, tip, needle and pot) to clean it every time i finish spraying.
I found general purpose thinners cleans up pretty well, 20L drum saves buying 4L of this and 4L of that.
Posted 06 January 2008 - 07:16 PM
Just wondering where the best place would be to get 20L of general purpose thinners from?
Also can you get away with using general purpose with the primer? I've got premium thinners for the top coats.
_Yella SLuR_
Posted 06 January 2008 - 08:06 PM
Edited by Yella SLuR, 06 January 2008 - 08:07 PM.
_Pete_
Posted 06 January 2008 - 08:30 PM
I was flicking through a trade magazine a month or so ago and came across a great article on gun cleaning tips. It was in Paint&Panel Magazine Nov/Dec 07, you might be able to find it online but I photocopied it and scanned it for my personal reference book.
Here it its anyhow, I'm not sure if you can read it, might need to save it and enlarge it etc.
any questions feel free.
_Yella SLuR_
Posted 06 January 2008 - 08:40 PM
Posted 06 January 2008 - 10:13 PM
I more use the general purpose for cleaning and thinning acrylic undercoat or any around the house job such as a trolley or fence (I paint alot) but i always stick to manufactures recommendations for 2K or top coats, clears etc for their specific thinner/reducer.Just wondering where the best place would be to get 20L of general purpose thinners from?
20L or larger drums of general purpose thinner or "gun cleaner" (cheaper than thinners) are avliable from all dedicated automotive paint suppliers, if there are none listed in the yellow pages near you try asking a few paint shops in your area where they get their supplies.
Posted 07 January 2008 - 09:54 AM
_Sammy_
Posted 08 January 2008 - 02:55 PM
if you use no frills brand general purpose thinners, use it for the entire job, which means all coats of paint. and this should probably work fine, but the finish may not be as good as if you use better quality thinners.
my understanding of the premium thinners is that they just give a bit better finish ... but im by no means a pro at spray painting
Posted 09 January 2008 - 04:05 PM
Sadly my old CIG Arnold Devilbiss gun didn't work quite well the last time I used it, which i'm to blame for as I used to leave paint in the gun over night if I was using it the next day. That article said the fumes ruin the seals etc.
The gun used to work quite well, are these meant to be a good gun and would I still be able to get a rebuild kit for it. It's probably 20 years old...
I'm going to pull it apart and have a look.
Posted 09 January 2008 - 05:44 PM
I'll probably end up using it as my primer gun. Will test tomorrow.
Posted 09 January 2008 - 05:47 PM
That needle packer as shown in the article above... I found if you do it all the way up the fluid needle becomes too tight and wont move when you press the trigger but if you back it off a bit it's fine. Is this the way it should be?
Posted 09 January 2008 - 06:07 PM
Posted 09 January 2008 - 06:34 PM
Posted 09 January 2008 - 07:37 PM
time to pull down and clean,friday soak gun ,fluid tip,air cap,needle in thinners
over weekend ready for monday
Posted 09 January 2008 - 07:44 PM
Thats how i have it on the work/home Star S770's, My Air Gunzo AZE GT3, and my Iwata W400, never had a problem.
#21
Posted 09 January 2008 - 08:36 PM
Sorry about all the stupid questions, just pretty new to all of this
