the heads that i removed off engine had several valves tops mushroomed i dont know what caused it but i have spent too much money on top end now to risk failure .
Posted 10 January 2008 - 04:31 PM
Posted 10 January 2008 - 05:14 PM
Edited by v8slrtorana, 10 January 2008 - 05:14 PM.
Posted 10 January 2008 - 06:35 PM
^^ What he said..get an expert to set it up...otherwise it will be coming off again.I only use ARP studs with comp cams locs.
Mushroomed valve stems could be from incorrect push rod length causing excessive valve side load.
Posted 10 January 2008 - 09:35 PM
Posted 10 January 2008 - 09:50 PM
Either that or remove the first couple of threads in the head.Should there be a flat washer under the stud ?
Posted 10 January 2008 - 10:23 PM
Posted 11 January 2008 - 08:56 AM
Posted 11 January 2008 - 11:01 AM
Posted 11 January 2008 - 02:28 PM
Posted 12 January 2008 - 06:34 AM
Posted 12 January 2008 - 08:19 PM
Posted 15 January 2008 - 12:51 AM
Posted 15 January 2008 - 03:42 PM
Posted 17 January 2008 - 01:40 AM
Posted 17 January 2008 - 12:32 PM
