Torana LX SLR 5000 Specs
15 replies to this topic
#1 _mars_
_mars_
Posted 14 January 2008 - 12:56 PM
Hello Guys,
Been away for a while, quick question, need some specs for an entry form to the Classic Adelaide for my SLR 500 A9X Replica.
Manufacturers Standard Weight LB and KG
Manufacturers Standard Power Output HP and KW
Just looking for the basic info if someone can help.
Many thanks, Mars
#2 _gmhgtr_
_gmhgtr_
Posted 14 January 2008 - 09:34 PM
CAMS State LX SL/R 5000 -1183 kgs
From Memory -216HP, which is roughly 161Kw.
(damn pollution gear)
:spoton:
Edited by gmhgtr, 14 January 2008 - 09:39 PM.
#3 _mars_
_mars_
Posted 15 January 2008 - 03:10 PM
Thanks GMHGTR, just what I needed.
Mars
ps Still got my XU1, market seems to have gone very quiet, no takers as yet, no real hurry though, will sell in time.
#4 _gmhgtr_
_gmhgtr_
Posted 15 January 2008 - 07:53 PM
PM sent Marsy.
:spoton:
#5 _keith1962_
_keith1962_
Posted 15 January 2008 - 08:43 PM
LH SL/R5000 had 240rwhp (179kw) i think
cheers Keith
#6 _gmhgtr_
_gmhgtr_
Posted 16 January 2008 - 07:59 PM
178.96 to be exact :) hehe, but you'd be spot on!
thank god for computers :P
#7 _gmhgtr_
_gmhgtr_
Posted 16 January 2008 - 08:02 PM
the LX has that little bit of a loss, not good at all, 24HP could make a real difference come to think of it as every little bit counts!
#8 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 16 January 2008 - 09:37 PM
Early LX SLR5000 (pre-Adr27a) was rated at 186kw (9.8:1 comp)
#9 _Yella SLuR_
_Yella SLuR_
Posted 16 January 2008 - 10:02 PM
^ I thought pre-ADR27A motors where 9:1 compression, they then boosted it to 9.8:1 after ADR27A to try regain some performance.
#10 _gmhgtr_
_gmhgtr_
Posted 16 January 2008 - 10:06 PM
hey early Litre8?
roughly 7/76?
12/76 have the Pollution Ger
Edited by gmhgtr, 16 January 2008 - 10:07 PM.
#11 _Yella SLuR_
_Yella SLuR_
Posted 16 January 2008 - 10:19 PM
CAMS homologation papers show 1192 for the LX SS, 1138.8kg for the LX SL/R 5000 and 1186kg for the LH SL/R 5000.
Shows 240 SAE BHP at 4,800RPM for the LH SL/R 5000. For the LX it only says "Detail changes to engine to meet Australian Design Rule ADR 27A for Exhaust Emission Control introduced. Basic Engine design and displacement unchanged".
I wouldn't necessarily go on the CAMS Homolgation sheets as being gospel, but there you go, specially when it has things like an LX SS 5000 in it.
Edited by Yella SLuR, 16 January 2008 - 10:20 PM.
#12 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
Posted 16 January 2008 - 10:23 PM
ADR27A came into effect around April or June 1977 from memory. This ADR brought in EGR etc (much more than just the old charcoal cannister)
#13 _gmhgtr_
_gmhgtr_
Posted 16 January 2008 - 10:25 PM
hey early Litre8?
roughly 7/76?
Let me revise;
Hey Litre8
How early was this?
roughly 7/1976
12/1976 Have Pollution Gear :(
GMH.
:spoton:
#14 MONZA1
MONZA1
  • 448 posts
Posted 16 January 2008 - 10:32 PM
I thought ADR 27A came into effect 1 July 1976.
#15 Dr Terry
Dr Terry
  • 3,341 posts
Posted 17 January 2008 - 07:12 AM
Hi Guys.
There seems to be a lot of confusion regarding 5.0-litre V8 engine specs.
According to my information it goes like this.
1. Early LH - 9.0 comp & 240 bhp (179 kW)
2. LH (eng no. HT24413 onwards) & early LX - 9.7 comp & 250 bhp (186 kW)
3. LX 1st July 1976 onwards (ADR27A) - 9.7 comp & 216 bhp (161 kW)
These changes were in line with the larger HQ/J/X series Holdens.
Type 1 is basically an HQ spec engine.
Type 2 is the HJ upgrade.
Type 3 is the same as an HX series Holden. (The loss in output was due to altered cam timing and different head flow for ADR27A).
The other thing to note is that these hp figures are 'Gross', whereas todays figures are 'Net', so they cannot be compared directly. An approximate conversion is 180 kw Gross = 120 kw Net.
Dr Terry
#16 _mars_
_mars_
Posted 17 January 2008 - 08:06 AM
Thanks everybody,
What you have given me is close enough for my entry, doesn't have to be exact but interesting information none the less.
Thanks again, Mars
ps look for my next question on rat traps.
