overheating
_todandkatslj_
Posted 30 January 2008 - 03:03 PM
Posted 30 January 2008 - 03:19 PM
As a bandaid solution, fit a thermo fan to the rad instead of the engine fan. That way the way will run when it gets hot!
_Leakey_
Posted 30 January 2008 - 03:31 PM
Posted 30 January 2008 - 04:04 PM
_Bigmac123_99_
Posted 30 January 2008 - 04:16 PM
let us know how it goes
_Herne_
Posted 30 January 2008 - 04:40 PM
When I get that bolt undone I like to squirt a good strong hose in the hole and watch the water coming out where the radiator pipes have been removed, you will be surprised at how much mud and gunk can come out.
Of course it could also be a head gasket or worse as mentioned above.
When and if all this above ^^^^fails take it to a radiator place and have them check your system.
Herne
Posted 30 January 2008 - 04:49 PM
Posted 30 January 2008 - 06:14 PM
incorrect timing
blocked radiator
wrong engine fan
dud water pump
blocked thermostat
just for starters!!!!
_73LJWhiteSL_
Posted 30 January 2008 - 06:20 PM
http://www.gmh-toran...showtopic=16117
Steve
_threeblindmice_
Posted 30 January 2008 - 07:07 PM
Posted 30 January 2008 - 07:48 PM
yes ..maybe..you had to change the fan to stop itcould you be using the wrong type waterpump?
http://www.gmh-toran...showtopic=15710
hitting the radiator tod.....
Posted 30 January 2008 - 07:56 PM
it is a blocked radiator.
_todandkatslj_
Posted 30 January 2008 - 08:19 PM
Posted 30 January 2008 - 08:22 PM
Posted 30 January 2008 - 08:27 PM
we can sort something out..want to borrow to suss it out???
Posted 31 January 2008 - 01:47 PM
The plug referred to in that post is next to the starter motor on a red 6.If you go the route of cleaning the radiator and reverse flushing the block etc be sure to undo the bolt down low on the engine block (I am assuming a 202 has one like the V8's do) and be a bit careful that it doesn't break whilst attempting to loosen it as they tend to rust in.
Mine fixed itself today....gave itself an automatic hot reverse flush!!!
I headed down the F3..but soon the engine hesitated..the converter had frozen (lpg), so I pulled over, released the cap slowly and the radiator started venting into my overflow bottle...I used that hot water to thaw the converter....I finally removed the cap completely and started the engine...I refilled the engine...the car had been running for about 5 minutes and i was trying to get hot water to flow thru the converter by squeezing all the hoses to force any trapped air into the radiator...eventually the converter started to warm..at this point i switched the engine off...2 seconds later water erupted from the filler neck and shot a column of water about 2 feet high..I checked the converter again...started the engine and slowly refilled the radiator..got in the car and drove the rest of the way to work sitting just above 80 degrees....which it never does....fixed.
Edited by FastEHHolden, 31 January 2008 - 01:48 PM.
Posted 31 January 2008 - 01:53 PM
lmao
Posted 31 January 2008 - 02:14 PM
The trip home will be the test....lets hope the trucks can stay on the black stuff today and not hit the rock wall
_waratah_
Posted 31 January 2008 - 04:53 PM
we found that once you get the crap out or moving putting a bit of wire mesh in the top radiator hose where it connects to the radiator, abit of silicon helps stop leaks.
checking it everytime you drive it decently gives you an idea whats floating around and you catch it.
Edited by waratah, 31 January 2008 - 04:53 PM.
Posted 31 January 2008 - 05:51 PM
read this link
http://www.gmh-toran...showtopic=13370
#21
_jima9x_
Posted 31 January 2008 - 09:34 PM
#22
Posted 31 January 2008 - 10:05 PM
#23
Posted 31 January 2008 - 11:21 PM
Put it in an old pot, put enough cold water in to cover it.
Heat the water up, (On the stove) the thermostat should open fully before it starts to boil.
I had one that only opened half way even at boiling point, was overheating in winter with a brand new radiator core.
New thermostat, fixed.
Paul
#24
Posted 01 February 2008 - 06:34 AM
#25
_The Baron_
Posted 01 February 2008 - 11:07 AM
He replaced existing water pump with an original GMH pump with cast impellor and all was fixed.
Cheap pumps with the fabricated tin impellor cavitate too easy.
Cooling system function can be broken down to two major parts.
Water flow and air flow.
Water flow too low and the heat is not moved to the radiator quick enough to cool the engine.
Water flow too high and the water distribution/circulation through the engine does not have enough residence time to absorb the heat efficiently and therefor carry it to the radiator. Parts of the engine remain hot as the flow bypasses those areas through the easier paths in the engine.
That is why it is not a good idea to completely remove the thermostat.
Air flow--you can never have to much although it can bring on the thermostat stutters--fixed by having a reasonable thermostat bypass path (hole in thermostat or external hose as per later holdens)
Just my 2 cents, I hope it helps a little.
