It may be up for sale soon as he is travelling overseas, full nut & bolt rebuild was completed in 2000.
Below are the specs.
Year/Make/Model
1968 Morris Mini Deluxe
Engine Hardware
Cooper S 1380cc - 110HP
Engine Accessories
73.5mm Pistons, lightened & balanced Cooper S rods, RE13 camshaft ground on 106 degree lobe centres, high-flowed 12G940 head, double valve springs, 1.5 roller rockers, Roller master double-row adjustable timing gears, 45mm Weber, K&N Air filter, Redline 6-inch polished inlet manifold, LCB ceramic coated extractors, Mick�s Metal craft alloy radiator, 10inch Davis Craig thermo fan, Davis Craig electric water pump, 2inch stainless exhaust, Genie turbo muffler, electronic ignition and a recently fitted brand new alternator.
Drive train Hardware
Four speed syncro straight cut close ratio gearbox, LSD diff imported from UK, Hardee Spicer output shafts, helical 4.11 crown wheel, competition clutch, lightened & balanced flywheel.
Breaks & Suspension
Koni front and rear adjustable shocks, front and rear adjustable rubber cones, front and rear adjustable camber kits. Cooper S Front Disc Brakes and Cooper S drums at the rear.
Rolling Stock
10x5 �inch GB Alloy wheels wearing 165/60 Yokohama A008 tires.
Bodywork
Honda S2000 Silverstone 2-pak paint with black GT-Stripes, Cooper S wide flares.
Interior Gadgetry
Re-trimmed �lipstick red� leather seats, doors and custom dash, autotechnica wood grain steering wheel, wood gear knob, sparco pedals, autometer tacho, speedo, water temp, oil temp and pressure, voltage, fuel and shift light, Pioneer CD head unit, Clarion VNET4150 amp, 7x10 Kenwood rear speakers.
Featured in Hot 4s, issue number 97 and as they quoted "The cam's now lumpier than a fat chicks thighs covered in cookies and cream"
Edited by BCR42Y, 02 February 2008 - 06:27 PM.
