Burnout Tyre Pressure
15 replies to this topic
#1 _Viper_
_Viper_
Posted 10 February 2006 - 10:17 PM
Hey all, just wondering would it be better to have low pressure in your tyres or high pressure? for more smoke and make it easier to spin??? what would be the best pressure to set the tyres at for some action?
-Clint
#2 _MYLJ_
_MYLJ_
Posted 10 February 2006 - 10:24 PM
40 PSI works best for me :spoton: :D :D
#3 LXCHEV
LXCHEV
  • 3,637 posts
  • Car:'76 LX - 383 Chev
Posted 10 February 2006 - 11:49 PM
I would probably listen to MYLJ, he seems to know judging by his pic!!! But yeah, I was gonna say higher pressure than normal, and 40 sounds about right. I've only ever been in one burnout comp before and I ran somewhere around the 40psi mark too. The higher the pressure you run, the easier the wheels will spin, but it'll probably wear out the centre of the tyres quicker too. Not sure if tyre pressure would have much effect on smoke produced???
#4 _jap-xu1_
_jap-xu1_
Posted 11 February 2006 - 06:36 AM
i always let them down a bit from normal so the it burns more than just the centre of the tyre
#5 _MYLJ_
_MYLJ_
Posted 11 February 2006 - 08:15 AM
At lower tyre pressure the tyres tend to balloon up like a drag slick (wears out the centre first) It also tend to make the car spongie and body roll more which in my case is not good for when doing dounuts
excesive pressure (45psi plus) starts the tyre ballooned up, and also wears out the centre of the tyre first ,but you tend to get less flex in the sidewalls ,making circle work easier on the car :D you get less smoke though.
The width of the tyre and the sidewall hieght also effect the amount of "ballooning" that you get
The more important thing than tyre pressure is tyre speed, have a guess at the tyre speed (in the avater pic) its around 120 to 140 miles per hour !
It doesnt matter how much air is in them, at that speed anything will smoke up :D
#6 _Yella SLuR_
_Yella SLuR_
Posted 11 February 2006 - 08:57 AM
Since your going for lack of traction, I'd go high pressure. Low pressure will just give you more traction and be harder on the drivetrain. Low pressure would also tend to wear on the edges, not the centre, high pressure will balloon out the centre, wear the centre, and give you a smaller contact area on the road.
What am I doing advising on burnouts?
#7 Heath
  • 18,401 posts
Posted 11 February 2006 - 09:27 AM
120-140MPH, HOLY $#!+
I'll definately use higher pressure in the Green Machine coz of the damn banjo, but I won't be going in any comps. :P
#8 _CHOPPER_
_CHOPPER_
Posted 11 February 2006 - 10:10 AM
I was also going to say around 40 PSI, but everybody else has beaten me to it. So I won't say anything.
#9 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 11 February 2006 - 10:17 AM
but you just did?
If you have the power then lowering the pressure will burn more rubber as the contact patch is longer...if you are underpowered it will just hook up and speer you off the pad or break something.
you will find due to tyre construction you don't get the centre raising up much when you give a tyre lots of pressure...at least nowhere near as much as old cross ply tyres did.
#10 _QIKSLR_
_QIKSLR_
Posted 11 February 2006 - 01:02 PM
I aggree, making smoke is about resistance. If it spins too easily it wont smoke. And put it in the highest gear you can go before it bogs down. Quality of tyre really matters too. 25 year old wreckers shit smokes poorly.
#11 _Viper_
_Viper_
Posted 11 February 2006 - 04:44 PM
woa thanks for all the tips guys, bunch of us are all going off to private property (no really it is!) n gonna fry some tyres n general circle work :) so 40psi it is then :) 6000rpm, drop the clutch n hold on! should be fun.. might even get a vid for yas to watch...
-Viper
#12 gtrboyy
gtrboyy
  • 3,235 posts
Posted 11 February 2006 - 04:58 PM
Dont forget that the higher tyre pressures give a bigger bang when the tyre explodes.I blew apart a tyre & damaged the 1/4 panel after the tyre blew.Its a lot of fun & looks good if it is a car your not worried about damaging.Have fun,dont forget to take pictures.
#13 _Herne_
_Herne_
Posted 11 February 2006 - 05:15 PM
hey Viper, be sure to post the photo's of the blown diff, broken axles etc too lol Joking mate, hope you have fun :)
Herne
#14 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 12 February 2006 - 06:03 PM
dont forget to soak your tyres in diesel for a few days........
#15 _wraith75_
_wraith75_
Posted 12 February 2006 - 06:53 PM
As a x tyer fitter just like chopper i wold leve tyers in a corner of your shed 4 2 years to harden and use dunlop there is more oil in them un like hankook wich use silica .And desel will help 40psi helps and then just give it sh$# good luck :spoton:
#16 _CHOPPER_
_CHOPPER_
Posted 12 February 2006 - 08:58 PM
The diesel will just make the tyres spin, not smoke up. Goodyears don't grip, so they should make the best burnout tyres.
