Hi, Just wondering if acrylic would go over 2 pack epoxy primer without any problems? Is there anything that needs to be done first?
Is Acrylic Compatable With 2 Pack Epoxy Primer.
Com_VC
, Feb 18 2008 04:11 PM
3 replies to this topic
Posted 18 February 2008 - 04:11 PM
Posted 18 February 2008 - 05:22 PM
I was told that the acrlic won't stick to it as well as it should, while another painter recommended it. Maybe one of the painters here can give us a real answer?
Posted 18 February 2008 - 07:03 PM
yes you can there are two ways to do this
1 is final rub finish in 600 wet &dry
2asabove but can put arcylic primer down before you paint and rub it
we do it this way so you dont get sink back and sand swelling marks which
is very common with arcylic paints,arcylic will sit alot better on 2k products than arcylic as is doesnt soak up the top coat colour when using arcylic product
any further question just pm
Posted 09 March 2008 - 05:46 PM
so it wouldn't be necessary to put down acrylic primer on top of the 2 pack epoxy then?
