Converting To Electronic Dizzy
Posted 18 February 2008 - 11:26 PM
Just need all the info i need when fitting Electronic Dizzy to a 186 engine in a LC 1970 Model.....
do i have to change any wiring...or remove any more parts....
what will be the effect on the ignition?? im guessing smooth start up as it will be bigger and better spark...but more info would be great....
Posted 18 February 2008 - 11:34 PM
_CHOPPER_
Posted 18 February 2008 - 11:38 PM
_Herne_
Posted 19 February 2008 - 12:10 AM
Herne
Posted 19 February 2008 - 12:03 PM
Posted 19 February 2008 - 09:46 PM
_Yella SLuR_
Posted 15 June 2008 - 10:27 PM
_73LJWhiteSL_
Posted 16 June 2008 - 12:29 PM
Thats all i did with the LJ.You should be able to bypass the ballast resister by installing a jumper on the ignition switch. That wil give you the full 12V required.
Steve
_Chriskoss-79uc_
Posted 16 June 2008 - 07:38 PM
All I have to do is, keep the old yellow wire (the original resisted 9v wire for points dizzy) on the new 12v coil.. and install a new wire which has the full 12v. This is done by unscrewing the fuse panel, connected another wire to the ignition switch (spade terminal or solder it on?) and running it straight through the firewall and onto the positive coil?
Is that all what's needed?
Edited by Chriskoss-79uc, 16 June 2008 - 07:39 PM.
_73LJWhiteSL_
Posted 16 June 2008 - 09:28 PM
The old points dizzy gets 12vs on starting (yellow wire) and then when the key is in the on position gets like 9vs on running (pink wire). So all you are doing is connecting the yellow wire during starting and running.
On the LJs its yellow and pink wires... not sure for others, but the resistive wire should have something writen on it with an ohms symbol.
Steve
Edited by 73LJWhiteSL, 16 June 2008 - 09:30 PM.
_Chriskoss-79uc_
Posted 16 June 2008 - 10:38 PM
Yeah on my UC there are 3 pink wires.. 1 fat one on its own, located top left of the fuse box, and two conjoined ones on the right in the middle..
I think I'll stick to the easiest way for me and run a seperate 12v wire.. Where should I solder this to? the fat pink wire on the left location?
Chris
Posted 16 June 2008 - 11:16 PM
Posted 16 June 2008 - 11:50 PM
No. 1 (green) would be OEM yellow wire and No.5 will power ur new coil.
Some good info here http://www.bcae1.com/relays.htm
Edited by ALX76, 16 June 2008 - 11:58 PM.
_Chriskoss-79uc_
Posted 17 June 2008 - 12:23 AM
Can the way I described be done though? By running a bare wire from the fuse box 12v to the ignition coil? It's a job I can do at home by myself without going out and getting new wires and a relay etc because I am lazy..
p.s when you timed the 202 in my care mate, you put white out marker on the timing mark of the harmonic balancer yeh? I found it so it made things much easier. There are 2 lines.. do I time it up in between these 2 lines?
Posted 17 June 2008 - 12:31 AM
It will work better with its own power supply, from the battery.
If i put the mark on the case at 6degrees then Yes, the two lines should line up (with the vacuum advance disconnected and plugged from the dizzy end...
Edited by ALX76, 17 June 2008 - 12:34 AM.
_Lostit_
Posted 17 June 2008 - 07:24 AM
_Chriskoss-79uc_
Posted 17 June 2008 - 07:13 PM
Please elaborate what you mean?14v not 12 v by the way.
And thanks Terry
Posted 17 June 2008 - 10:08 PM
