Commodore Rim Stud Pattern?
2 replies to this topic
#1 _pallbag_
_pallbag_
Posted 24 February 2008 - 09:39 AM
Someone here will know - is the stud pattern for Commodores all the same thoughout the range, eg does VB fit VY ?
#2 dattoman
  • 16,488 posts
Posted 24 February 2008 - 10:52 AM
5 x`120 as long as were not talking 4 cyls
All same
12mm metric threads
Till VE then they went 14mm
#3 _CHOPPER_
_CHOPPER_
Posted 24 February 2008 - 01:05 PM
As Neil said.
Stud patterns:
VC/VH Commodore 4 cyl used 13x5.5" Torana rims with 5x4.25" PCD.
All others up to and including VE used 5x120 PCD
Studs:
All up to and including VZ used 12mm wheel studs.
VE uses 14mm wheel studs.
Centrebores:
VC/VH 4 cyl: 63.5mm
All other up to and including VZ: 69.5mm
VE: 66.9mm ( 99% sure, check with ROH to confirm )
