Body Number
_mrfmad_
Posted 26 February 2008 - 12:14 PM
Anyone have this information i would appreciate it.
Thanks for all your help members.
Michelle
_threeblindmice_
Posted 26 February 2008 - 01:13 PM
Posted 26 February 2008 - 01:26 PM
Even if the '69 cars did have an ADR tag - it doesn't show the Body Number only the Vehicle Serial Number (aka Chassis Number) that is also stamped on the inner guard.
If there is no evidence of an inner guard change or alteration to the stamping, then by definition this is the Chassis Number of your car.
If your car has all the GTR features and there seems to be no evidence of the above then the likelihood is that the car is genuine.
The Body Number (from the Trim Tag) cannot be cross referenced for authenticity. As threeblindmice mentioned it can be matched (as a rough guide) with Body Numbers from cars where the completion date is known.
The best thing is to post what numbers you have (including the VIN) and forum members can take it from there.
Bazza
_mrfmad_
Posted 26 February 2008 - 01:50 PM
Im sorry i think i am calling the body number the chassis number. I have a number under engine bay near passenger guard (chassis number). How do i tell if this chassis number is off a GTR
Its close to other LC GTR numbers
I dont doubt it is a GTR Just someone mentioned on this forum it must have been rebodied (Just out of the blue this comment came when i was asking a question about welding guards.) which i dont believe is true. But does the chassis number match anything anywhere as the tags dont have this number.
Im restoring this car & wouldnt put blood sweat & tears tears tears into non GTR Shell or be forever convincing people it genuine thats all.
Thank you
Michelle
I am happy to post number is it safe for others to have this number on the forum?
Posted 26 February 2008 - 03:19 PM
Hi again MichelleHow do i tell if this chassis number is off a GTR
You can't tell anything from the Chassis Number other than that the car is an LC Torana and the factory that produced it. You can say whether the Chassis Number is in the same time frame as the VIN. eg. If the VIN says Oct '69 and the Chassis Number is in mid 1970 range - then there is a problem. Similarly, if the Body Number is in a date range that doesn't accord with the completion date associated with the VIN - again, a problem.
Unfortunately, the General didn't record Chassis Numbers or Body Numbers so cars can only be identified by the VIN. Even then, you can never really be sure that the VIN tag was originally attached to the car under examination. Experts have been fooled by a good mock-up.
I am happy to take a look at the numbers if you don't want to post them - but posting them shouldn't be an issue.
Bazza
Posted 28 February 2008 - 09:18 AM
sorry to but in,but i've got a question just to confuse everyone,i've got a 69 gtr that the chassis number matches the body id tag,my mates got a 69 gtr but the numbers don't match,and i've also red on the forums that other peoples numbers don't match.
i was wondering if Bazza can shed some light on the subject
thanks Rob
Posted 28 February 2008 - 10:17 AM
I have noticed that phenomenon a couple of times too. I am only guessing that it occurred because the Brisbane plant numbered bodies sequentially reqardless of body style. If this is true - Chassis Number 1 would also be Body Number 1 and Chassis Number 2 would be Body Number 2 etc. etc. I am guessing this breaks down because the Chassis Number and Body Number are allocated at different times in the production process. Someone who has knowledge of the process may be able to correct me.
This prenomenon does not occur with the Adelaide built cars because the bodys were numbered according to body style. eg Chassis Number 1 may be a GTR Body Number 1, Chassis Number 2 may be a 4 door Body Number 1, Chassis Number 3 may be a 2 Door S Body Number 1 etc.
It should be understood that Body Numbers and Chassis Numbers are two different things and they do not have to match.
Bazza
Posted 28 February 2008 - 12:05 PM
HQ's from some plants have a similar phenomenen, where there is actually a firewall number that means very little and it doesn't match the chassis or BODY numbers. But it is close (within 50 or so), so to rebody a car you need more than the rails and ID plates - you need to know to some degree of accuracy what the firewall number has to be. And this is where a few rebodied GTS350 coupes have tripped up in recent times.
I suppose the moral is - Fakers/Fraudsters beware. Someone out there can nearlly always pick something you didn'y know about. And I suppose this applies not just to ID plates, but to little minor differences between the "right" body and a replacement.
Byron
Posted 28 February 2008 - 01:28 PM
_gtr161s_
Posted 01 March 2008 - 06:30 PM
When i first seen the number under my tag i thought it was a paint code...co-incidently it was similar to rally red paint number but it was the body number
Posted 01 March 2008 - 09:55 PM
Posted 02 March 2008 - 06:18 PM
It's actually the last digits of the PSN (which is the suffix of the VIN number minus the letter on the end if it has one), eg (in HJ terms) 8Q37TEH780789J, the numbers on the back of the ADR plate will be 789. For the earlier style VIN there will be no letter on the end so it will just be the last 3 digits. Not all plants did this. I'm pretty sure it was Elizabeth (Adelaide), but possibly others.under the adr tag (near wiper motor) they did write the body number in red texture, i guess that way the body/ paint tag matched everything else.
