Gasless Mig Welders
Posted 15 March 2008 - 05:32 PM
_SLR_6_
Posted 15 March 2008 - 06:17 PM
gassless mig's work, but make a mess of things too easy.
Posted 15 March 2008 - 06:23 PM
_Yella SLuR_
Posted 15 March 2008 - 08:51 PM
As you rely on the wire to create the flux shield like stick you need to pull your welds rather than push like with normal MIG. Left to right if your right handed.
I have stick, mig and oxy. If I had my time again, I'd probably do a good inverter type stick welder, and spend the extra $250ish on the TIG lead, then grab a bottle of Argon. I think that gives you pretty good capacity, but I also love TIG welding.
Edited by Yella SLuR, 15 March 2008 - 08:54 PM.
Posted 16 March 2008 - 07:09 PM
It's dear on the gas, but better quality on the weldment!
There are ways around that too!
I'me not a believer on 'gassless migs'!
I have tried them, with good results, but still not convinced!
Boilermaker for 26yrs! I quite enjoy the the taste of Argoshield!
Posted 16 March 2008 - 09:28 PM
_CHOPPER_
Posted 16 March 2008 - 11:06 PM
Posted 17 March 2008 - 08:13 AM
Tim
_Yella SLuR_
Posted 17 March 2008 - 05:59 PM
^^^ if you have a gas mig, you just put in gasless wire in, and don't turn on the gas.
Posted 17 March 2008 - 06:14 PM
I thought you had to reverse the polarity.if you have a gas mig, you just put in gasless wire in, and don't turn on the gas.
_Yella SLuR_
Posted 17 March 2008 - 09:41 PM
Edited by Yella SLuR, 17 March 2008 - 09:45 PM.
_Pete_
Posted 17 March 2008 - 10:06 PM
My personal opinion is the Gasless stuff is really only suitable for welding up a farm gate off a generator out in the paddock etc, for automotive sheetmetal/fabrication the Gas set-up give a much nicer more sound weld.
The Boilermakers here are the blokes we need to listen to, anyone who sits on the end of a MIG gun and an Angle Grinder all day would know their stuff.
_Yella SLuR_
Posted 17 March 2008 - 10:11 PM
Posted 18 March 2008 - 02:32 PM
That sounds like the go.^^^ if you have a gas mig, you just put in gasless wire in, and don't turn on the gas.
_3point3_
Posted 18 March 2008 - 06:50 PM
Posted 18 March 2008 - 08:04 PM
3point3 nailed it. Using gas is how a mig was designed.
_racyrabbit_
Posted 20 March 2008 - 04:19 PM
_Pete_
Posted 20 March 2008 - 07:47 PM
Mind you my old man picks apart everything in the world but still he knows his stuff.
Another vote for GAS here! you would only end up disappointed buying a gasless.
_lx-304_
Posted 22 March 2008 - 07:17 AM
Posted 22 March 2008 - 05:15 PM
And the copper would take the heat away quicker rather than spreading it through the panel???and when repairing holes and welding in plates etc,a piece of 5mm copper plate is your best freind.placing this behind the weld you can fill the gaps with no ugly bits hanging off the back.(this is because the weld does not take to the copper.)
#21
_CHOPPER_
Posted 22 March 2008 - 10:09 PM
