Changing Tie Rods & Ball Joints
_crumpledoor_
Posted 21 March 2008 - 10:32 AM
I have bought all new tie rods, ball joints and suspension rubbers for the front end of my LX. I have change the rubbers before but I have never changed a ball joint or tie rod before. The ones on the car are the factory originals. Any tips on how to change the tie rods and ball joints. Im sure they will not be easy, but I am also sure there are some little tips you guys can give me to make the job easier. Obviously apart from going somewhere to get it done. Any help you guys can give me would be much appriciated.
Posted 21 March 2008 - 10:36 AM
Advice on changing, i just follow the service manual.
_crumpledoor_
Posted 21 March 2008 - 10:42 AM
Posted 21 March 2008 - 08:39 PM
Bottom ones are bashed out with a large hammer, i use correct diameter pipe that fits over the ball joint to support the control are when hammering, installation is basically the reverse, supporting the arm from the opposite side i place the bottom ball joint in evenly then hammer it in with a socket that fits snugly on the bottom. A better way to do it is have a shop press them in for you. Most guys see use my method without a press.
Do a search on good ball joints, top ones like MOOG can cost upwards of $200 for a set, but it is money well spent if you are worried about
highway driving
P.S. This job also requires removal of the stub axle obviously and anything else in the way, seperating the stub from the joints can be a pain and i have one of those cheap "ball joint removal tools", looks like a folk, for help there.
Edited by ALX76, 21 March 2008 - 08:42 PM.
Posted 21 March 2008 - 08:54 PM
Posted 21 March 2008 - 09:01 PM
Forgot to mention that when you have the wheel off and go to separate the stub from the joint that the bottom are will be under tension from the suspension spring, if it flys out it can kill you so either use spring compressors first or with your chassis stands supporting the chassis, use a trolley jack under the lower control arm to prevent this.
Do you have chassis stands and a decent trolley jack for this job?
Posted 21 March 2008 - 11:17 PM
American Autos Upper MOOG K5108 $77.00
You can buy them from the USA. Two MOOG uppers and two MOOG lowers delivered International Priority (3-5 days) to your door for USD $134.86 including freight.
http://www.rockauto.com
Edited by ls2lxhatch, 21 March 2008 - 11:19 PM.
Posted 21 March 2008 - 11:20 PM
_crumpledoor_
Posted 21 March 2008 - 11:29 PM
Posted 22 March 2008 - 11:36 AM
Lower K5103
Upper K5108
LH-LX Front Suspension
American Autos
Half price delivered from USA. Enter K5103 or K5108 in part number search.
Rock Auto
Summit Racing
Edited by ls2lxhatch, 22 March 2008 - 11:40 AM.
Posted 22 March 2008 - 11:50 AM
_crumpledoor_
Posted 22 March 2008 - 05:28 PM
_crumpledoor_
Posted 22 March 2008 - 06:11 PM
Posted 22 March 2008 - 06:17 PM
Posted 22 March 2008 - 06:34 PM
What is a good brand?
_CHOPPER_
Posted 22 March 2008 - 10:11 PM
The problem is they are left and right hand threads. Toranas use right hand thread on both sides. HQ - WB uses two L/H and two R/H tie rod ends in their front ends.OK I have been working on the tie rods today. After I did the passenger side I realised that the boxes had different codes. The codes are the same except for one ends in "L" and one in"R". I didnt realise but I have put the "R" on the passenger side. I went to put the drivers side on before I realised all of that and it wont thread on. Should it still thread on or do right and left have different sized threads? I wouldnt imagine they would but you never know. Or have I just been given one that is the wrong product. Help I am stuck, please help! Codes on the boxes are: PTE195L & PTE195R
Posted 22 March 2008 - 10:14 PM
Posted 22 March 2008 - 10:22 PM
Because Torana owners can tell the difference?^ im not going to ask why.
_CHOPPER_
Posted 22 March 2008 - 10:32 PM
Hope this confuses everybody.
_Brewster_
Posted 22 March 2008 - 10:34 PM
#21
Posted 22 March 2008 - 10:45 PM
Two very different steering systems.Because the HQ - WB's have the adjusting rod between two tie rod ends. One end of the rod is L/H thread, the other end is R/H thread. This way, you turn the rod and it lenghtens or shortens. There is one pair on each side of the car. And a track rod in the middle, connecting two of these tie rod ends, the idler arm and steering box.
#22
_CHOPPER_
Posted 22 March 2008 - 10:51 PM
#23
Posted 22 March 2008 - 10:54 PM
#24
Posted 22 March 2008 - 10:58 PM
#25
_CHOPPER_
Posted 22 March 2008 - 10:59 PM
