Lh Torana Max Engine Size?
_BlownOutlaw_
Posted 02 April 2008 - 09:40 PM
Without me searching everywhere to find out, what is the maximum legal engineered engine size for a LH Torana sedan in NSW ??
Does anyone know what a LH SLR5000 weighed ?
_Yella SLuR_
Posted 02 April 2008 - 09:57 PM
_BlownOutlaw_
Posted 02 April 2008 - 10:05 PM
Using 1183Kg that only works out to 347.8 ci
Posted 03 April 2008 - 12:22 PM
Posted 03 April 2008 - 01:39 PM
Posted 03 April 2008 - 03:35 PM
The NSW rules for weight used in the calculation is as follows.
'Original weight� is the original (unmodified) �tare weight� of the sedan version of the vehicle model fitted with the largest engine available for the model but without optional accessories such as air conditioning and tow bar.
http://www.rta.nsw.g...ns_nov_2007.pdf
Sedan
Kerb weight: 1143 - 1183 kg (2520 - 2609 lb)
The means you can have an LS1 346 cu in but not an LS2 364 cu in.
Edited by ls2lxhatch, 03 April 2008 - 03:36 PM.
Posted 03 April 2008 - 06:46 PM
_Yella SLuR_
Posted 03 April 2008 - 08:27 PM
Spotlight on LH/LX Torana says 1143 - 1183 kg's (depending on model), but from memory, the registered weight of my 2850 LH SL was 1183kg.
Even the Owner's Manual is vague on the V8's, only mentioning the kerb weight of a 6 cyl. SL/R sedan as 1204 kg's, or 1613 maximum loaded weight.
Holden Torana Performance Handbook gives hat and hip room dimensions, but no weights for any models???
LH Holden Service Manual - 1183 kg's for again, only 6 cyl 4 Door "SL/R".
As above, I know for a fact that Yella is 1300 kg's, because I had to weigh-bridge her for rego, and that is what is on the rego papers.
Edited by Yella SLuR, 03 April 2008 - 08:29 PM.
_Yella SLuR_
Posted 03 April 2008 - 08:35 PM
Posted 03 April 2008 - 09:01 PM
Details from Holden hatch brochure.
https://cache.gmh-to...ch/brochure.jpg
SL 1183 kg (2610 lb)
SS 1213 kg (2674 lb)
I guess that the SL weight is the 6 cyl and the SS weight is the V8.
My WA rego papers for the hatch list the tare as 1204.
Edited by ls2lxhatch, 03 April 2008 - 09:07 PM.
_Yella SLuR_
Posted 03 April 2008 - 09:35 PM
_GMH355_
Posted 03 April 2008 - 10:16 PM
_moot_
Posted 05 April 2008 - 06:29 AM
that is the highest weight yopu can go off in nsw.it really sucks as i wanted a big blockThe weight listed for the LH SLR5000 in the appendix of the RTA's Light Vehicle Code of Practice is 1205kg.
_BlownOutlaw_
Posted 05 April 2008 - 08:13 AM
1974 LH SLR5000 Torana - 1205 Kg
There is no listing for LX Torana's or any other type of LH.
So therefore using this weight it means you can register up to 354 ci.
_BlownOutlaw_
Posted 05 April 2008 - 08:20 AM
_Yella SLuR_
Posted 05 April 2008 - 08:48 AM
_moot_
Posted 05 April 2008 - 11:58 AM
dont get me wrong but arent slr5000's v8's?
haha jsut kidding
_GMH355_
Posted 05 April 2008 - 04:25 PM
You are probably thinking of the new National Code of Practice for Light Vehicle Construction and Modification (NCOP). NSW still hasn't adopted these rules.Actually I thought the rules had changed to limit engine size more, but, my RTA book from 1994 still lists formula as original weight x 0.294 which is the same as what it is now.
NCOP
Have a read if you have a spare few hours
Yella, the RTA's documentation on vehicle weights actually specifies the LH SLR5000 fitted with 308 cu V8 weighs 1205kg.
I reckon Redslurs 1275kg is closer to the mark in terms of weight.
Edited by GMH355, 05 April 2008 - 04:28 PM.
_Yella SLuR_
Posted 05 April 2008 - 05:36 PM
The weird thing is it isn't documented in any of the historic Holden documentation, only reference to the six pot. Weird but true, check out the documentation for yourself.
Posted 05 April 2008 - 05:43 PM
Move to NZ and you can put an 500 cube alloy big block in one if you wanted.Thanks. From what I can work out with RTA modifications to light vehicles its original vehicle weight X 0.294 for naturally aspirated engines.
#21
_GMH355_
Posted 05 April 2008 - 06:28 PM
I have attached the page from the appendix. There are probably many more inconsistent weights for many of the old holdens listed. But someone back in the day pencilled in a figure on a new vehicle compliance sheet and that has now became fact.
There was a similar discussion in the drag racing forum some time ago regarding vehicle weights and how the "offical" LH/LX weights seem inconsistent. Has anyone weighed their stock SLR5000 and would like to share what they found?
Edited by GMH355, 05 April 2008 - 06:31 PM.
#22
_Yella SLuR_
Posted 05 April 2008 - 06:39 PM
#23
_BlownOutlaw_
Posted 05 April 2008 - 07:24 PM
Yep just found it, mine weighed 1300 KG.
But thats without the original fuel tank and a plastic fuel cell installed and with a chassis kit. But also probably a lighter gearbox in the 2sp glide. But then again a 9" diff probably adds a bit but probably evens out ?
Gotta be more than 1205 KG though. I'll just show the engineer my old rego paper with 1300 KG on it.
#24
Posted 05 April 2008 - 08:07 PM
LX Hatch
SL 1183kg
SS 1205kg
I have also seen kerb weights of 1143-1183 quoted for the LH/LX. I think it is reasonable to assume the following.
1143 kg 4 cyl
1183 kg 6 cyl
1205 kg V8
It would be interesting to weigh a 100% original SLR or SS and see how it compares.
The tare would have been provided by Holden when the car was complianced. I would think that the only way you could get the figure changed from the published weight of 1205 would be to get a letter from Holden stating it was wrong.
Edited by ls2lxhatch, 05 April 2008 - 08:12 PM.
