Skyline Calipers?
28 replies to this topic
#1 _scalpa1_
_scalpa1_
Posted 21 April 2008 - 09:10 PM
Hi everyone ive heard that you can put r32? skyline calipers onto torrys,please can anyone tell me if i need any particular stub or is it a caliper bracket and what discs do you run hq? or torana? ant help would be appreciated cheers tony
#2 _brett_32i_
_brett_32i_
Posted 24 April 2008 - 10:54 AM
it will be r31 skyline/pintara you're after with integrated handbrake?
or do you mean front?? not straight forward, i used torana stubs, r32 or 33 (cant remember) calipers, territory rotors, falcon hub, custom adaptor.
Edited by brett_32i, 24 April 2008 - 10:56 AM.
#3 _rocket_
_rocket_
Posted 24 April 2008 - 01:31 PM
R32 gtr calipers. The 25mm disc type, sumitomo on the side, adaptor bracket, hq style stubs, swapped left to right and so on.Hq discs, if using Torana stud pattern, buy blank rotors and drill to suit.
#4 _Wangman_
_Wangman_
Posted 24 April 2008 - 04:34 PM
Isnt there an issue with bumpsteer using hq stubs? Also how do you buy blank rotors and drill them to torana pattern? i thought lh/lx/uc were all "hat-type" rotors ie the hub and rotor are one piece.
Jaime
#5 _rorym_
Posted 24 April 2008 - 07:45 PM
Yes...use UC
Use HQ stub axles as stated.
#6 _@milco@_
_@milco@_
Posted 09 March 2009 - 09:28 PM
who makes the adapter plates?
#7 _evil UC hatch_
_evil UC hatch_
Posted 09 March 2009 - 09:32 PM
Rocket does them
#8 _@milco@_
_@milco@_
Posted 09 March 2009 - 10:04 PM
how much mate?
#9 _slr6000_
_slr6000_
Posted 09 March 2009 - 11:27 PM
� used the r32 callipers, LX stub axles but had to clearance the lower control arms and bump stop pads on the sub frame to use them, hq disks and cut out the adapter plates from some 10 mm plate.
Edited by slr6000, 09 March 2009 - 11:28 PM.
#10 AbsynthHatch
AbsynthHatch
  • 741 posts
  • Name:Mark
Posted 10 March 2009 - 12:57 AM
Rocket who?
#11 _rocket_
_rocket_
Posted 10 March 2009 - 07:16 AM
Send me your postal address, and Ill send you a template.
#12 _rorym_
Posted 10 March 2009 - 06:00 PM
Careful on the calipers...only early R32 GTR ones are correct..not later ones..Better to look for 300ZX ones...they are correct.
#13 GML-31
Posted 10 March 2009 - 06:03 PM
Rod put the diagram up on photobucket with a link here to save you emailing heaps...
#14 _rorym_
Posted 10 March 2009 - 06:08 PM
It will have to be to scale.
#15 _slr6000_
_slr6000_
Posted 10 March 2009 - 07:29 PM
Yeah I�m using the 300zx callipers but not the HQ stub axles, with the LX stub axle the Calliper sits closer to the lower control arm. When the suspension is fully extended it hits the calliper on full lock and needs to be notched out. Bit more work than using the HQ stub axles but i think its the better way to go.
Edited by slr6000, 10 March 2009 - 07:32 PM.
#16 _slr6000_
_slr6000_
Posted 10 March 2009 - 07:30 PM
#17 _rocket_
_rocket_
Posted 11 March 2009 - 10:09 AM
I dont have photobucket Kev, but I have emailed some pics to other members, if they want, feel free to post them.
#18 _datpsi_
_datpsi_
Posted 11 March 2009 - 07:27 PM
I in the middle of setting up this conversion on my lj track car!! Still looking for a suitable rotor to make most of larger rotors but camry is closest i have found to date( possibly the new sti wrx rotor still to check this wk end).
i have machined rotor face off from standard hq rotors and will need to machine down the outer diameter of this. This will ensure no major mucking around with new hubs etc. I will also need to slightly machine down the inner diameter of the rotor so will sit over the hq hub. this will hopefully allow me to run the largest rotor possible!!
Need to get this sorted before i start making dogbone to mount caliper but hopefully should be up and running within a few wks!!
#19 _rorym_
Posted 13 March 2009 - 06:32 PM
Will be interesting to see the pics.
#20 _Racelx_
_Racelx_
Posted 13 March 2009 - 07:15 PM
G'day guys
Just received a copy of a rough template off rocket and will provide an accurate copy to the forum once i have got them made upo together with a disc / hub combination as soon as possible. Looking at VT 296 x 28mm discs, HQ stubs and a hub adaptor from a place in Croydon Vic with 300zx calipers.
#21 grina05
grina05
  • 131 posts
Posted 24 March 2009 - 05:49 PM
would these be the corect ones?
http://cgi.ebay.com....Z...A1|240:1318
#22 _rocket_
_rocket_
Posted 24 March 2009 - 08:01 PM
I ll put up some pics tomorrow of mine, with everything.
#23 _rocket_
_rocket_
Posted 25 March 2009 - 07:57 AM
Heres a couple.
#24 _rocket_
_rocket_
Posted 25 March 2009 - 08:03 AM
You need wheels spacers for 15 in simmons, but 14 inch Hotwires fit without.
#25 _datpsi_
_datpsi_
Posted 25 March 2009 - 01:00 PM
so did u end up using the vt rotors?? who done the hub adaptors and how much??
