currently on my LH the M/cyl has a big and a small nut for the brake lines, does the large nut line go to the large nut on the prop valve?
what part number should I quote when i am getting a new master cyl?
sorry for being vauge, im in a rush.
master cyl and brake line Q's
makka
, Feb 16 2006 05:29 PM
4 replies to this topic
Posted 16 February 2006 - 05:29 PM
Posted 16 February 2006 - 09:48 PM
Large nut goes to the rear brakes
P7210 is the early cylinder
P7369 is the later cylinder
technically LH should have the early cylinder
Posted 18 February 2006 - 01:38 PM
but the later one is better?
are they both 1 inch bore?
Posted 18 February 2006 - 01:44 PM
Same
Just different nut configurations
If you to to the other master you will have to redo your pipes
Posted 18 February 2006 - 01:52 PM
so the early one has the large nut at the rear?
