650 holley on a 253
24 replies to this topic
#1 _blenda_
_blenda_
Posted 19 February 2006 - 09:11 AM
hey guys i just bought a 253 and its got a 650 holley on it i was just wondering is that to big or would i have to down size it
#2 _Herne_
_Herne_
Posted 19 February 2006 - 09:41 AM
Unless the 253 is red hot you dont need a 650 holley. A 465 Holley would be more than adequate for performance and dare I say it - economy.
Herne
#3 _CHOPPER_
_CHOPPER_
Posted 19 February 2006 - 10:36 AM
And if it is a stock 253 that doesn't get pushed hard, he could get away with a 350 Holley.
#4 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 19 February 2006 - 02:29 PM
And regardless of the size chosen, for daily drivers Holleys aren't always economy friendly.
#5 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 19 February 2006 - 03:05 PM
A bucket of fuel with a hole in it may offer better economy.
#6 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
Posted 19 February 2006 - 03:06 PM
^ that was the first prototype Holley.. ;)
#7 _TORANASS_
_TORANASS_
Posted 20 February 2006 - 09:10 PM
Whats a predator then? A 44galon drum with 2 holes in it?..lol
John
#8 _Bomber Watson_
Posted 20 February 2006 - 09:30 PM
yeah, and a flash emblem.
#9 MRLXSS
  • 12,416 posts
Posted 21 February 2006 - 11:13 AM
Well i just borrowed a 650DP Holley with Mech Secondaries on my stroker and i think its a bit to much! haha jus a lil! i would much prefer a Vac Secondaries Carby... Such as a Smaller holley or a Quadrajet... presonally a quadrajet
#10 _TORANR AMORE_
_TORANR AMORE_
Posted 21 February 2006 - 12:55 PM
I had a 253 with fueled with a 650 Holley and it was definately too much, it used to run fine until I tried to give it some gas.
#11 _Joanne_
_Joanne_
Posted 22 February 2006 - 12:27 PM
I HAVE EXACTLY THE SAME PROBLEM, I HAVE AN LX WITH A 253 AND IT HAS A 650 HOLLEY.. I WAS PLANNING TO GET A 450 HOLLEY VERY SOON AS IM SPENDING ALOT OF MONEY ON PETROL, BUT, MY QUESTION IS, WOULD MY CAR GO SLOWER ONCE I PUT A SMALLER CARBY ON IT??? ALSO, IM PLANNING TO STROKE IT TO A 308 SO DO YOU THINK I SHOULD JUST LEAVE THE 650 ON THERE OR WOULD A SMALLER CARBY SUCH AS A 460 STILL BE BIG ENOUGH IF I STROKE IT?
#12 _TORANR AMORE_
_TORANR AMORE_
Posted 22 February 2006 - 12:38 PM
650 would be fine on a 308, but my question is why do you want to stroke a 253? Why not just use a 308 block?
#13 _Joanne_
_Joanne_
Posted 22 February 2006 - 12:49 PM
Because i was told that a 253 and a 308 had the same block but with a different stroke.. is this not right???
#14 surfmaster
surfmaster
    Marineboy
  • 2,019 posts
Posted 22 February 2006 - 01:52 PM
Later 253's in the VH Commodores had four barrel factory carbies which werent too bad - perhaps one of these would be more suitable?
#15 Dr Terry
Dr Terry
  • 3,333 posts
Posted 22 February 2006 - 02:50 PM
Hi Guys.
Joanne said
" Because i was told that a 253 and a 308 had the same block but with a different stroke.. is this not right??? "
NO it is not right. The 253 & 308 have the same stroke, but a different bore (3.625 vs 4.00). Problem is you can't bore a 253 block to 4.00" to make it a 308. You might as well just buy a 308 to start with.
surfmaster said
" Later 253's in the VH Commodores had four barrel factory carbies which werent too bad - perhaps one of these would be more suitable? "
The Q-Jet carby was factory fitted to ALL Blue 253 V8s, in the VC, VH & WB series cars.
Dr Terry.
#16 _A9_X_
_A9_X_
Posted 13 June 2006 - 01:41 AM
Had a 465 vac sec holley on my 253 LX installed and tuned by Doug Chivas at Revesby many moons ago, a real nice carby that give good economy and performance.
#17 MRLXSS
  • 12,416 posts
Posted 13 June 2006 - 02:07 AM
Yeah get a Quadrajet id say... if you really want a holley get a 465 vac sec one!
#18 _Lostit_
_Lostit_
Posted 13 June 2006 - 10:01 AM
Big blocks from the states used to run with 2 barrel carbies.
" Bigger isnt always better"
Lostit
#19 _Yella SLuR_
_Yella SLuR_
Posted 13 June 2006 - 10:51 AM
Good Dr, where these the same 780 CFM carbs as on the 308 with smaller jets, or smaller quadrajets? Would be interesting to know.
#20 _EXLXSL_
_EXLXSL_
Posted 13 June 2006 - 11:05 AM
I had a VC with 4.2 and Quad. Also had a manual for the car but I'm not sure if it was a Holden or Gregory's manual - I remember comparing the carbs between 4.2 and 5.0. Venturi sizes were the same but jets and needles (primary and secondary) were different. Car ran fine with it. I did try a 465 too and it ran a lot harder but I think it sat a little higher due to having to use an adaptor and put it too close to the bonnet. Ended up going back to the Quad.
On my old 253 SL hatch I changed to a 350 Holley - got better power and economy over the 2 barrel Stromberg and was also better than the Commodore.
#21 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 13 June 2006 - 01:20 PM
I had a vac sec 650 on my 253, and even after a tune and re jet, it doesnt compare to the Quaddie I have now
#22 _Herne_
_Herne_
Posted 13 June 2006 - 01:27 PM
Thats cos a 650 Holley is waaaaaay tooooooooooooo largeeeeeeeeee for a 253 :)
Even a 600 Holley is a bit large unless the 253 is very hot.
But we gotta try these things in the never ending chase for more power lol
Herne
#23 _A9_X_
_A9_X_
Posted 13 June 2006 - 01:29 PM
I actually changed my inlet manifold as well to a redline, didnt have any clearance issues at all, cant remember now what power it made but combined with a HMHeaders extractors and dual 2inch from memory it went pretty hard
Edited by A9_X, 13 June 2006 - 01:33 PM.
#24 limo
limo
  • 2,673 posts
Posted 13 June 2006 - 05:05 PM
Back in mid 80s I had LH 253, mild cam redline manifold with 450 Holly vac
secondaries. With 4 speed and 2.78 LSD, was excellent, lots of grunt but good
on fuel if stay on primaries.
#25 _Loki_
_Loki_
Posted 13 June 2006 - 10:30 PM
Running a 450Holley on my 5.2L.
Probably would benefit from larger, but with these fuel prices - who can afford to put the foot past halfway anymore anyway :)
The question about the 600 on the 253 losing power - probably find it'll increase performance dropping down the carby size O.o
