You CAN make more HP with LPG, just have to get the right setup...
Gas research twin throttle bodies, 400 and 440 CFM on a 308.
Check my other posts for more details on the car.
Posted 13 June 2008 - 09:55 PM
Posted 13 June 2008 - 10:02 PM
Posted 13 June 2008 - 10:15 PM
Posted 13 June 2008 - 10:22 PM
Posted 13 June 2008 - 10:28 PM
Posted 14 June 2008 - 11:38 AM
Posted 14 June 2008 - 12:03 PM
Edited by torana, 14 June 2008 - 12:05 PM.
Posted 14 June 2008 - 03:13 PM
Posted 14 June 2008 - 06:55 PM
Posted 14 June 2008 - 08:11 PM
Posted 14 June 2008 - 08:15 PM
As opposed to a petrol powered ADR271A compliant 308.You CAN make more HP with LPG, just have to get the right setup...
As oppsoed to what exactly?
Posted 14 June 2008 - 08:29 PM
Compression is fairly high using ACL high comp pistons .040" over, I havent tested the comp ratio yet but I'd hazard a guess at 8:1, cam is smooth, the exact specs again I'm unsure so I'll ask the engine builder.. I think he said stage 3.. but that could mean anything. Anyway the car was smooth with generous Hp on ULP so I hope it's going to suit the LPG as well.. the dyno will speak volumes so when I get it tuned I'll post the graph up for all to see.that looks sweet mate, what comp and cam are you running? i am thinking of geting rid of the petrol tank when my gas 355 goes in (hopefully before the end of the year), cut the floor out of the boot and weld a fake drop tank in and use two long skiny tanks in the drop tank part and cover it over so i still can put stuff in the boot.
Posted 15 June 2008 - 12:21 AM
Posted 15 June 2008 - 01:25 AM
Thanks for that, the dizzy is a replica MSD street fighter that'll be ripped out asap, I've already had to hack it to suit the MSD 6AL CDI ignition.. as soon as the rego comes about i'll go for the best electronic MSD setup I can buy.. I'll never waste money on shit ignition components again..they are leds, i welded a plate in over the old tail light hole and bolted up the leds. the filler neck is for the curant lpg tank same as yours( mounted in the boot) its dual fuel at the moment but when the new motor goes in the petrol tanks coming out. if the enging was running on petrol before you should get your dissy regraphed (if you havn't already) as gas likes lots of advance at idle and only a little more once its reving unlike petrol which needs a little at idle and alot once its reving.
