1 step candy paint
2 replies to this topic
#1 _fitzsi_
_fitzsi_
Posted 23 June 2008 - 10:12 AM
2 Pack One Step Candy Spray Painting?
I am going to paint my sons car in 2 pack One step candy apple spray paint soon ( Colour - Coke Red )
The base paint is a black colour ( Paint Brand - Spies Hecker & Coke Red Candy is Spray Chief )
I want to know one if I can spray the 2 pack base colour before the candy and rub it back a bit to get out any peel before I lay the candy on and then the clear.
Also can I spray the doors boot and bonnet off the car with the amont of coats of paint without any colour problems when the cars all together
#2 _1QUICK LJ_
_1QUICK LJ_
Posted 23 June 2008 - 03:06 PM
do not rub the base coat at all, this will make the colour patchy. just spray colour wait 30 min then coat with clear. i would spray the car with all panels on if possible. if you spray the boot and bonnet separate i would advise you do it the same time when painting the car, do 1 coat on the car then 1 on the other panels and so on, DO NOT spray panel for panel down the sides or side panels separate. you must have all the side panels on and walk the entire length of the car down the sides or you will get light strips between the panels where the paint overlaps on each panel. try not to overlap coats extra anywhere as it will be a completely different shade of colour. theres nothing worse than a bad candy job.
#3 TerrA LX
Posted 23 June 2008 - 03:36 PM
Rub back, orange peel and 2pac should not be used in the same sentence.
